Very happy to meet all of you.
Also "happy" to know that I'm not being over sensitive, with the obvious changes that has been put onto my car without my consent/knowing.
Since the ECU-update in April, my automatic gearbox is now rubbish, the fuel economy has changed and the smoothness when driving is very different. Not really the same car that I bought five years ago.
I have been in correspondence (4 months) with the dealer who performed the update, Opel (Vauxhall) DK and lastly the Danish association for car owners - FDM.
It all boils down to me having to prove that the changes mentioned above, are directly linked to the update. All though I haven't had any trouble prior to the update. Of course this would require that I had the car fully tested on a dyno before the update, to register gearshift ratio, torque, HP, consumption etc.
There is a small opening in letting someone test the cars performance, to see if the HP is now less than 136. Still this is no real basis for a legal claim towards Opel DK/EU. And also its not the main problem to me. The biggest issues are the gearbox changing "very late and very hard". Also the engine braking when gearing down is a disaster now. Used to be very comfortable and smooth. The gearbox had a perfect timing in terms of what gear to chose when going back on the throttle. The reaction times is also prolonged and sort of slow.
So far no one have been able to answer whether its possible to re-install the original software package to the ECU. Opel and FDM argue that its impossible.
What I have learned so far is, that the gearbox software is so well integrated into the main ECU, that it cannot be adjusted separately. But there is a chance slight that the EGR-valve can be deactivated, without it causing an error when testing.
- Have anyone managed to conclude (solid proof) that the original ECU-software can be re-installed?
- Is there any chance that the gearbox can be separately adjusted, so the "gearing" becomes more smooth and comfortable?
- What experiences are there with overriding the EGR-valve to remove the "throttle-lacking-sensation" when driving 70-90 km/h?
Best
Thomas
