21 - 29 of 29 Posts
ROBINHOOD said:
так как установки нет, ее следует переставить согласно директивам. Я могу подключиться к вам удаленно и установить программу.
Спасибо. Для начала мне нужно смонтировать провода и установить qh. Что мне необходимо сделать для возможности удаленного программирования? Какая цена?
Discussion starter · #22 ·
Do you know how to do the wiring?
60 GBP
60 GBP
The price is normal. I placed the order "qh" and will receive it soon. To install "qh" I will use your instructions. So far, this is the only instruction that I have found for Astra K. The Russian forums are full of information on installing "qh" on Astra J, Zafira, Insignia. In Astra J, Zafira in most cases there is always a wiring for "qh", but in Astra K and Insignia there is no wiring. Therefore, I will have to independently lead the wires into the engine compartment and connect the "+" to connector 7. I will connect the control wires to the climate control unit (as in your photos). I also need to connect a 100A fuse. It is a pity that you do not have a photo of the wire and fuse connection in the engine compartment🙁.
The wires, apparently, will have to be routed to the engine compartment, approximately in the area of the pedals. Where did you run the wire to connector 7? No photo? You have excellent instructions, but the photo of the engine compartment is a little lacking ... But I will try and I hope I succeed! Do you need mdi for remote programming? My friend has it. By the way, does qh work on your car? I read this thread and concluded that initially qh did not work due to the lack of a program.
Discussion starter · #25 ·
yes, it wasn't working at first. But then I programmed it for both q. h. and active front grille. I made this work without it. You won't need 100amper insurance. Because insurance is already available at exit 7. To carry the cable in, you need to remove the wipers and the plastic protection there completely. Then you'll see the bundle of wires coming in. You get the connection for the ground from the iron under the q.h.
Sorry, I didn't quite get it. What is an "active front grill"? What is needed for remote programming? Laptop and mdi? And then you will be able to connect to my car and activate qh?
It is very easy to retrofit. You pull the plus cable into the engine compartment to the fuses and take the minus cable directly from the carrier on the center console. The control goes to the climate control unit (you can see in the pictures). If you have any questions, just write to me and I will describe it in more detail. Finally, Robin has to change the software in the climate control unit. It's great and I can only recommend it.
21 - 29 of 29 Posts
