Hi everyone.
I have recently noticed that even after changing the master cylinder, dmf and clutch kit with csc my clutch pedal would lose pressure in roundabouts, especially when making more "aggressive" turns from time to time.
I've read something about the crankshaft having too much endplay but I am no car expert so an explanation for that would be quite nice.
The above picture is from this YT video:
It shows the end of the camshaft and how damaged it is. I took the camshaft sensor off my car to take a look and mine looks nothing like that.
Do note that my astra has 304.500 km.
The engine is B14XFT 150PS.
I am about to also change the clutch actuator elbow with the newer model and drain the clutch brake fluid but I doubt that will change the problem that occurs only in sharp turns.
Any help would be appreciated, thank you!
