Clutch + Flywheel replacement
245 views 6 replies 3 participants last post by  wr96
#1 ·
Hi folks,
Having issues with my clutch pedal needs a good pump to get back to not feeling half the travel does nothing.
I understand this is a common issue, the clutch is due on milage soon anyway so figured I'd bite the bullet and replace the clutch, flywheel and slave cylinder and hope this also resolves the clutch pedal issues too.
However I can't find stock of flywheels anywhere!
Could someone assist with a supplier to try or part numbers so I can have a ring around myself.
I did get a price from a garage of ÂŁ1440 for this work which isn't far off the mark I was expecting but I have the capacity to do this myself and save a little money to go towards other problems that are cropping up on the car.
I can get VIN number after work model is 17 Plate astra K 1.4 petrol Turbo.
Thanks in advance!
