Its not going good for me, two major problems, Clutch and now Power steering failure .
I bought this car less than 3 weeks ago, 2017, from a private seller, so not under any warranty, I am still having issues with its clutch pedal loosing pressure, biting point moves far too close to floor, and on one occasion the car was in gear and brakes on, engine stalled as the loss of pressure engaged the drive. The pedal starts to feels very light when this issue is about to happen. twice it packed up completely, but I was able to pump it up and down a few times to get going, so did not need towing away.
Today I took the car out, everything was ok until I parked up in a shopping car park, came back started engine and tried to manoeuvre out of parking and the steering wheel could not be steered! It was rock hard, I needed strength from both hands to turn little at a time, when I checked the dashboard there was a message saying Power Steering failure or some words to that effect, and a red Warning saying Drive with Caution! I have driven cars with power steering failures, but never seen a steering wheel as hard as on this. It requires mighty strength to steer even when the car is rolling.
There was no way I could have manoeuvred the car suddenly if there was an emergency to avoid a collision! It is one disaster after another, such a nice car otherwise but shocked how it is ridden with mechanical problems. Astra K s seems they are plagued with clutch/brakes and power steering problems. Not just Diesel manual but even my 1.4 petrol Turbo is behaving the same, it would would it not as clutch hydraulic operation would be same for both diesel and petrol, as well as brakes would also be the same, along with Power steering, these components have little to do with engine type, so Vauxhalls better sort mine out under recall before i take them to trading standards.
I tried to see if there were any fault codes stored in the system, OBDII hand held code reader, but no codes were stored, yet steering was still unresponsive, i also tried to switch on and off ignition several times even in that car park, it did not reset power steering problem.
Next I check continuity on all its fuses , all were intact, I pushed back all relays in case any had popped out lose, a couple of them were not fully pushed in well, but they were not out by far.
Tried again, and the Power steering warning came on dash board , so still the same, rock hard, then I was going to attempt to bring the car closer to home, so just as I started to pull out suddenly the power assistance came back, so now this is worrying thing as this failure could happen again and it would be worst if it happens whilst you are driving fast on winding road.
