Repeat fault
scocart
Repeat fault
Post by scocart » Tue Mar 24, 2020 7:37 pm
Hi, this is my first post so hopefully I’ve got it in the right place.
I have purchased a second hand 68 plate Astra, 11k miles now on the clock, purchased in November 2019.
Since then, the engine management light has been on three times, all of those times it has been repaired by my local dealer. The light is now illuminated again all with the same fault.
The RAC code reads
RAC DIAGNOSTIC SYSTEM
System Type: ENGINE
DTC: P015B,Heated oxygen sensor (HO2S) 1 , bank 1 - delayed response lean to rich
They’ve changed the sensors and the problem continues.
Any ideas please?
Re: Repeat fault
Post by Redman » Wed Mar 25, 2020 9:16 pm
I am presuming you are referring to the 1.4 t gdi LE engine (B14XFL/T). This engine is fitted to a fair amount of American cars, so research forums such as the gm cruze. Example below.
The original poster eventually had the cat converter replaced along with both O2 sensors a year ago and hasn't posted since, take that how you may.
All this after having the O2 sensor replaced several times to no avail.
https://www.cruzetalk.com/threads/check ... in.233121/
Good luck, let us know how you get on, what ever happens as it will help others
scocart
Re: Repeat fault
Post by scocart » Wed Mar 25, 2020 9:21 pm
Hi, no sorry.
I’m in the UK and it’s a 1 litre petrol turbo
Crosseyxpower
Astra Model: Sri nav
Re: Repeat fault
Post by Crosseyxpower » Wed Mar 25, 2020 9:29 pm
If it's running lean then either there's a O2 sensor fault or a vacuum leak in the intake after the sensor for the air filter. These would be your best place to look first. If not then i suggest a compression test on the cylinders.
scocart
Re: Repeat fault
Post by scocart » Wed Mar 25, 2020 9:32 pm
Ah ok, I’ll mention to the garage. Many thanks
Crosseyxpower
Re: Repeat fault
Post by Crosseyxpower » Wed Mar 25, 2020 10:27 pm
Does the car run hesitant or Jerky when cold after startup?
scocart
Re: Repeat fault
Post by scocart » Wed Mar 25, 2020 10:28 pm
Hi, no, runs with no issues
Re: Repeat fault
Post by Redman » Thu Mar 26, 2020 6:59 am
Hi, no sorry.
Still research the sites for the cruze as well as this site, as it is essentially the same engine as the astra k and they have all the same type of issues.
A few have mentioned this problem and have had an ecu update performed, not always rectifying it unfortunately. Is the car stop start?
scocart
Re: Repeat fault
Post by scocart » Thu Mar 26, 2020 7:25 am
Ahh ok. Sorry for my lack of knowledge.
Yes it’s S/S
mullybully
Astra Model: 150 hp SRI
Re: Repeat fault
Post by mullybully » Thu Mar 26, 2020 3:01 pm
I have a 1.6 T and have had the engine management light fault coming on and off frequently over the last 12 months. I have on previous visits to the dealers been told that I hadn't tightened the petrol cap tightly enough, apparently you must tighten it until it "clicks". I did that and the fault came back. They then went through all the cylinder compression tests, eventually the dealer decided it was a faulty spark plug, so all four plugs were changed. That "fix" lasted 2 weeks before the warning light came on again.
So to cut a long story short they had it back again and they must have had a discussion between the mechanics and came to the conclusion that the fault was the same as they had seen frequently in the Vauxhall Corsa range. So they changed the "Evap purge valve".
The problem so far has not happened again, So maybe this Purge valve is the answer to your problem. If you search for it on the internet it seems like lots of owners have had this problem and have had everything changed at great expence and time but to no avail. It will cost about £100 fitted to have this valve changed.
