Rear USB Port - Part numbers
Re: Rear USB Port - Part numbers
Post by AdieMcc » Sun Feb 11, 2018 7:18 pm
Yeah few people have. Easy aswell
Mike88
Post by Mike88 » Mon Jun 11, 2018 11:03 pm
Could anyone provide a detailed guide on how to do this? Thank you!
When I remove the rear plastic cover will it have a connection inside for the two USB sockets or I have to get wires there?
Ollie222
Astra Model: 1.6T 200 Elite Nav
Post by Ollie222 » Tue Jun 12, 2018 1:54 pm
Does anyone know if the rear ports are the same on MY16 cars as MY17 cars?
Just wondering if the later ones have a higher power output.
Also is the transformer built into the USB ports with the part number 13412444 ?
Post by AdieMcc » Tue Jun 12, 2018 2:34 pm
think its in the how too section for installation
Mike88
Post by Mike88 » Thu Jun 14, 2018 5:16 pm
Could you provide a link, a cannot find it. Thank you!
Post by AdieMcc » Fri Jun 15, 2018 6:32 am
I can't see the how too either. best off messaging cornishtaz for the part numbers if he's still got them. you need the plastic trim, double USB port, little connectors, 1 meter of speaker wire to connect to the cigarette lighter. its pretty easy to do feed the wire through the centre console pull the cig lighter up out of the hole and connect the wires to the bottom of it for power. you need to connect the wire to 2 pins on the back of the USB port.
Mike88
Post by Mike88 » Sun Jun 17, 2018 10:36 pm
Thank you! I found the part numbers on the top of this thread.
Should I remove the center console as well to feed the cable and place the plastic trim? Is there a how to on this?
aaaaplay
Astra Model: RS-V 1.6T
Astra Options: Touring Pack (Adaptive Cruise/Sunroof)
Astra Colour: Nitrate Silver
Post by aaaaplay » Mon Jun 18, 2018 5:35 am
I have actually bought the parts from cornishtaz as he sold his Astra K I believe.
The rear panel on the centre console pulls off (pull towards the rear of the car). You should also be able to remove the cigarette lighter and then thread the cable through the back to the cigarette lighter up front without pulling everything apart.
However, I'm yet to install anything yet, I've just had a look around in my car.
Post by AdieMcc » Mon Jun 18, 2018 8:36 am
you'll have to pull the gearstick gater up to get to the cig lighter. should be able to just feed the wire through to the front.
Mike88
Post by Mike88 » Mon Jun 18, 2018 9:15 am
Thank you so much for the answers!
I have an electric brake. Should that be a problem when removing the center console?
