Mirror defrost fuse
darren7649
Mirror defrost fuse
Post by darren7649 » Thu Sep 12, 2019 5:15 pm
Hi all
I recently had my wing mirror replaced and I’ve just noticed that my mirrors are no longer heating up. I’ve checked the fuse box and it appears to have been removed and I don’t know the type to replace it with.
Does anyone know?
Re: Mirror defrost fuse
Post by astraowner » Thu Sep 12, 2019 6:37 pm
I just looked at the manual
I found 2 fuses that i thought, from the naming in the manual, would be the fuse.
First one is in the fusebox in the engine bay.
Fuse 30 - Mirror Defrost (Missing on my car that has heated mirrors, so maybe this is if you have the heated front windscreen ?)
Second one is in the fusebox behind the cubbyhole/Powerflex bar
Fuse 14 - Exterior Mirror (This fuse is present, it is a 7.5A fuse)
If these are not the ones you have found missing, please tell me where and what fuse number, and i will tell you what fuse rating is there.
Post by Redman » Thu Sep 12, 2019 7:00 pm
If fuse 30 is missing as astraowner has verified on his car and his mirror heaters work, I wonder if they are fed from the heated rear window (fuse 29 engine fusebox) as the mirror heaters are activated from that switch.
Post by astraowner » Fri Sep 13, 2019 1:48 pm
Well as you can see in this picture that is my fusebox, fuse 30 that is located as the lowest of the 3 fuses in top of the picture nearly in the center of the box, is missing (Empty space just below the 2 pcs 7.5A fuses)
Fuse 29 is the big one a little offcenter to the left just below the 3 fuse positions. It is rated 40A
Here is the manual with the fusebox and fuse numbers on page 231
https://www.vauxhall.co.uk/content/dam/vauxhall/Home/PDFs/owners/owners-manuals/astra/astra-owners-manual-february-2016.pdf
