Ignition live location
UKTog
Astra Model: SRINAV
Post by UKTog » Tue May 14, 2019 8:19 pm
OK so I've added a 12v socket and USB ports into the boot, all works perfectly fine but they're currently a permanent live connection, normally this wouldn't be an issue but they have power LEDs on them, so I was wondering if there is an easy to locate ignition live either behind the removable panel on the left hand side (preferred) or anywhere else in the boot that I could wire a relay up to?
Thanks guys
UKTog
Astra Model: SRINAV
Re: Ignition live location
Post by UKTog » Tue May 28, 2019 8:26 pm
Any ideas guys?
Rico76
Astra Model: 1.6 CDTI Dynamic
Post by Rico76 » Tue May 28, 2019 9:14 pm
Hello, ignition plus you get from the 12 V socket in the center console. It is the purple cable.
UKTog
Astra Model: SRINAV
Post by UKTog » Tue May 28, 2019 11:00 pm
Thanks, do you know if that is the closest to the boot?
Rico76
Post by Rico76 » Wed May 29, 2019 5:27 am
Morning,The next one probably not, in the boot you will definitely find something. There are still the ECUs, but there would be no power to this not to influence.
Robjohnston
Post by Robjohnston » Wed May 29, 2019 11:52 pm
It’s very easy to access the wiring for the centre console power socket, simply remove the panel on the driver’s side of the centre console (by driver's left foot) by pulling from the rearmost section (its forward section pushes into a recess moulded into the soundproofing at the firewall) It’s an accessory feed so not second stage or live while cranking. You’ll see the wiring loom going up by the metal bracket.
Post by astramaster » Thu May 30, 2019 1:02 am
behind the (left) removable panel or anywhere else in the boot
Why is everyone pointing the centre console?
He asked for an ignition live point in the back of the car.
Rico76
Post by Rico76 » Thu May 30, 2019 7:41 am
That's why.
Any ideas guys?
If you can name it a safe ignition plus rear that does not belong to any ECU, that would be very interesting.
Post by Scotty_b » Thu May 30, 2019 2:49 pm
Surely running a wire is simple enough.
