Fuse box
Mikewall-84
Astra Model: Sri 150bhp sport tourer
Astra Options: Tints,keyless entry & start electric tailgate
Astra Colour: Flip chip silver
Re: Fuse box
Post by Mikewall-84 » Sun Aug 12, 2018 7:00 pm
Yeah bought one for it for the ing live don’t want to mess with the main loom figured iAd take the permanent live and earth from the battery terminals
2017 Astra Sri 1.4 150 turbo flipchip silver rear tints keyless entry/start
Re: Fuse box
Post by danh23 » Sun Aug 12, 2018 7:06 pm
It easy to use the piggyback and use the rearwiper fuse which turns dashcam on with ignition and turns off when turn engine off I've had that done to mine since my last Astra I owned and never failed me
Mikewall-84
Re: Fuse box
Post by Mikewall-84 » Sun Aug 12, 2018 7:14 pm
Originally hoped to find a fuse near the battery in the boot to use to make for easier installation
Re: Fuse box
Post by danh23 » Sun Aug 12, 2018 7:17 pm
The hardwire kit I use is nextbase that has a huge cable length which could be reach the front from the rear easy enough
Mikewall-84
Re: Fuse box
Post by Mikewall-84 » Sun Aug 12, 2018 8:07 pm
Yeah the mio one has loads of cable but all three feeds are at one end
Re: Fuse box
Post by danh23 » Sun Aug 12, 2018 8:09 pm
Nextbase 1 has the piggyback and earth together with no other connectors
Mikewall-84
Re: Fuse box
Post by Mikewall-84 » Sun Aug 12, 2018 8:43 pm
Much simpler the mivue needs a memory feed to retain settings ect has little to no reserve battery power
Re: Fuse box
Post by danh23 » Mon Aug 13, 2018 5:37 am
I'd use nextbase hardwire kit that will allow parking mode to be use depending on the dashcam if that has it in settings which is useful and to find a fuse you'll need find a fuse that only works with ignition on ie rearwiper
Mikewall-84
Re: Fuse box
Post by Mikewall-84 » Mon Aug 13, 2018 7:12 am
Yeah going to use the rear wiper for the ingnition feed,park mode being another reason for hard wiring always handy to know which scumbag hits your car in car parks and drives off as many do,iav even had a guy try to do one having pulled into the space behind me hit me square in the rear bumper while I was sat in the car .lucky for me I had a tow bar fitted at the time so he did more damage to his van than he did my car
Mikewall-84
Re: Fuse box
Post by Mikewall-84 » Tue Aug 14, 2018 9:34 pm
Just to update went ahead brought a permanent live from the battery and used wiper for ignition feed all of which was a pointless exercise as the mio smartbox turns out not to be smart at all,it’s merely a permanent power supply that sets a timer for 36 hours.so any members that use the mio cams don’t bother with the smartbox.
Anyone know of a reasonable hard wire kit for dash cams
