astra k exhaust trim weird size?
bailey1878
Post by bailey1878 » Mon Jul 23, 2018 11:39 pm
hi wondering can anyone help me out ive trailed the internet ebay etc and cant find anything that will fit as a exhuast trim cover for my 17 plate astra 1.4 turbo,
its a drop down exhaust but its a weird size the pipe seems to measure about 64 mm drom left to right but 90mm from top to bottom
tried countless universal trims wont go near it anyone else had any luck?
much appreciated
bailey1878
Re: astra k exhaust trim weird size?
Post by bailey1878 » Mon Jul 23, 2018 11:40 pm
forgot to mention its a pcp car so i cant remove the exhaust and fit a new one in as il be handing it back in 3 years
150nav
Astra Model: 1.4t 150 sri nav. Parking pack. Winter pack
Astra Options: Duel zone c/c. 18" bi colour alloys.
Astra Colour: Lava red.
Post by 150nav » Tue Jul 24, 2018 11:01 am
Pipe is 64 dia, appears to be bigger front to back as it is cut at an angle, trim that will fit over 64 dia will fit.
bailey1878
Post by bailey1878 » Wed Jul 25, 2018 9:06 am
cheers mate yeah its about 64 just its a weird shape front to back about
il try what you said thanks
bailey1878
Post by bailey1878 » Wed Jul 25, 2018 9:09 am
will this fit?cheers
bailey1878
Post by bailey1878 » Wed Jul 25, 2018 9:26 am
will a 64mm fit even though the exhaust is 90mm front to back as in pics?.
150nav
Post by 150nav » Fri Jul 27, 2018 9:10 pm
You are not taking a true measurement, it is cut at an angle the sharper the angle the longer it will appear top be, if it was cut square across it would be and is 64mm dia! 50 years in engineering, trust me!!
bailey1878
Post by bailey1878 » Fri Jul 27, 2018 11:42 pm
so a 64mm exhaust will fit?
Post by Scotty_b » Sat Jul 28, 2018 3:29 pm
You could cut it straight and fit a nicer tail? It's only mild steel so will cut like cheese compared to stainless.
You may have to trim the plastic surround as it'll sit higher, but would be worth a bit of effort.
bailey1878
Post by bailey1878 » Sat Jul 28, 2018 8:26 pm
cheets mate but i cant modify it to that extent as ive got to give it back in 3 years to the dealer un modified just looking for a temp cover for the exhaust that i can take back off before i hand it back
