!.4 i sloppy throttle ...
kevsterRD250
Post by kevsterRD250 » Fri Jun 08, 2018 7:31 pm
Hi folks had my 2016 Astra 1.4 non turbo over a year now and am still suffering with a sloppy throttle-the first bit of the throttle does nowt then it suddenly kicks in -the garage that its been back to on numerous occasions "cant replicate it out on test" I have kicked off with Vauxhall HQ its now going to be looked at yet again several people have driven it and it is dire to the extent of being dangerous especially if you try and nip out of a junction quick it will bog down and still the garage dont see it help!!
Ivanzu
Astra Model: 1.4T
Re: !.4 i sloppy throttle ...
Post by Ivanzu » Fri Jun 08, 2018 9:58 pm
Try turning off the TC and see how it behaves like that.
AussieKOwner
Astra Model: RS 1.6T
Post by AussieKOwner » Fri Jun 08, 2018 11:07 pm
i had a focus st that did this. drive by wire (no physical link between pedal and tb) and the connections between the pedal module and loom were bad. took them ages to find. grab a cheap elm327 adapter and check it yourself but you will only see pedal signal, not tb position
kevsterRD250
Post by kevsterRD250 » Thu Jun 14, 2018 9:04 pm
tried the TC no difference
