Android Auto.
Gkf9
Android Auto.
Post by Gkf9 » Fri May 18, 2018 6:39 am
Anyone any Idea why it only connects 60-70% of the time, it's driving me fecking nuts!
I have a Samsung S8 with original cable, but still only connects when it feels like it.
Don't know if it's the app or the car? Maybe the car because sometimes even the USB stick with my music doesn't fire up.
Anyone else with same phone etc have any probs?
TIA
Astra K 1.6 SRI CDTI Nav (136) Diesel/ Summit White.
CharlieMike
Re: Android Auto.
Post by CharlieMike » Fri May 18, 2018 7:49 am
No idea. I have an s8 and it connects 95% off the time. It's very rare that i have to try connecting a second time.
Gkf9
Re: Android Auto.
Post by Gkf9 » Fri May 18, 2018 8:19 am
I find when it doesn't connect it's really hard to get it to connect again. Unless I turn off the ignition etc and start again.
PITA
Kpkna
Astra Model: K (2018)
Astra Options: 1.4 125hp
Astra Colour: Darkmoon blue
Re: Android Auto.
Post by Kpkna » Fri May 18, 2018 11:43 am
Same here!
I think it's a problem with usb of the car, because when AA it's not working I unplug the cable and connect it through an usb hub. Works every time. After a while it's not working with usb hub again and i have to connect using only the phone cable. again it's working all the time. Till i found this workaround , I tried many different solutions, multiple versions of AA, install and uninstall, cache wipe out of google services... none of them did solve the issue.
Astra K 1.4 B14XFL 125hp Darkmoon blue
Astra G 1.7 CDTI 80hp Blue Metro
Re: Android Auto.
Post by danh23 » Fri May 18, 2018 12:47 pm
It's same on mine and I use Samsung S9
Gunde
Re: Android Auto.
Post by Gunde » Fri May 18, 2018 2:14 pm
The USB outlet for AA is underpowered. But a quality cable can make a huge difference. I had to buy a new one to solve my disconnect issues.
Re: Android Auto.
Post by danh23 » Fri May 18, 2018 3:01 pm
I had brought cable off Amazon which works 9 times out of 10
Frostie36
Re: Android Auto.
Post by Frostie36 » Fri May 18, 2018 3:43 pm
Gkf9 wrote:Anyone any Idea why it only connects 60-70% of the time, it's driving me fecking nuts!
TIA
When aa doesn't connect properly, are you left with a blank screen on the car display? I had that issue but a software update for the cars intellilink sorted it and it's worked flawlessly ever since.
I went through so many usb cables trying to sort the problem, from cheap ones to expensive cables, none helped but after the software update on the cars intellilink every single cable works for aa, even the cheap ones so I really wouldn't bother buying an expensive cable for aa as it's not necessary.
Sent from my SM-G935F using Tapatalk
awlfc
Astra Model: 1.4t sri nav
Astra Options: Climate, park assist, intelli lights
Re: Android Auto.
Post by awlfc » Fri May 18, 2018 5:26 pm
Mine always connects now. But it csn be so slow it csn take 5 miles before I csn use Deezer or Waze
Gkf9
Re: Android Auto.
Post by Gkf9 » Fri May 18, 2018 9:09 pm
TIA
No I don't get a blank screen, any idea how I find what version intellink I have?
Or what version your update is? My car will be due it's second service in the next month or so, I'll ask if it can be updated if it's not the latest.
