Auto lights disabling
Bogbody
Re: Auto lights disabling
Post by Bogbody » Thu Mar 26, 2020 1:51 pm
In the UK the light sensitivity setting for the sensor is not correct.
It keeps switching the lights on and off, usually in late afternoons when the sun is low and bright.
The lights need to be on or off - in worst case I've had them switch on and off along an avenue of trees. To other drivers it looks like you are flashing your lights at them. Here they take it as a go signal and pull out of junctions.
I would like to control exactly when the lights are off or on. At the moment I can only control to have them on. I do not want them to flash on and off as they please.
Vauxhall do not appear to be intetested in the light sensor settings.
Gunde
Post by Gunde » Thu Mar 26, 2020 3:02 pm
Corbil wrote:
Tue Mar 24, 2020 6:56 pm
Here is the disassembled switch
What did you break on disassemble?
Astra K 1.6 CDTi. Mods: Leatherlook seats, heated rear seats, heated armrest, footwell lights, light in glovebox, light in boot storage compartment, gear surround ambient light, reversing camera, pedalbox, wood trim and black felt interior.
Corbil
Astra Model: 1.6 Cdti Innovation 136bhp
Post by Corbil » Thu Mar 26, 2020 4:20 pm
the brown part that is attached on the fog buttons from the back side......you cannot see that from the picture. The wheel now rotates 360 degrees
Post by astraowner » Thu Mar 26, 2020 6:05 pm
I agree that the light sensor is sometimes retarded.
I have also driven for an hour or so, with the dipped beam and rear lamps on, even though the light is very plentiful and if i stop at a gas station and go get some coffee and start it up, it will detect that the light is ok for DRL.
It seems that it sometimes gets itself stuck in "We need light on" mode, even though it is not needed.
Strange thing is that the light sensor on my previous car, Zafira B, was much better. You would think these sensors would get better over time, or atleast work as good as the older parts, but this is not the case here sadly.
880PEL
Astra Model: OPC-line 1,6T Automatic
Post by 880PEL » Thu Mar 26, 2020 7:47 pm
Meanwhile sun is shining low on horizon yes, there is plenty of light and yes, automatic setting switches dipped beam on for reason. Be visible for others out there!
So does the Astra, so does the Passat B8 with it's multiple light sensors and sensitivity settings.
My driving habbits prefer letting useful tech take over :)
Corbil
Post by Corbil » Thu Mar 26, 2020 10:42 pm
My previous Corsa D, Astra G and most now my Vw Eos work exactly as they design to. Sun is up, lights are off.....Sun is down lights are on. Entering a tunnel lights on after 2 seconds, exiting tunnels lights are off after 5 seconds. SO SIMPLE.
There is no sense that while entering the same 600 meters long tunnel other car brands immediately turning on their lights and the Astra needs the end of the tunnel to decide whether or not to turn them on. And when it decides to do it, it never turns them off until I reach my destination.
Keep your driving habits and hi tech staff for yourself, and let me decide what I need my car to do for me.
Arbe_GTC
Astra Model: Opel Astra 5dr
Astra Options: GSI Line 19.5 1.6Turbo
Contact:
Post by Arbe_GTC » Thu Apr 02, 2020 8:22 pm
Arbe_GTC wrote:
Thu Mar 19, 2020 7:40 pm
Hi from spain,
The light switch from Zafira C its valid (anti-fog front and rear lights switch works ok) for disabling the auto lights, but the color is RED. But....
You dont need the light switch from Zafira C.
The stock lights switch is fully valid. and the anti-fog works. :lol:
Proof:
my car have ILUX matrix Led lights
regards
Sorry guys!
The light switch is from Zafira C, not Zafira D
I cant edit the post.
P/N 20930746 (for LHD) (no manual leveling) front/rear anti fogs
P/N 20930740 (for RHD) (no manual leveling) front/rear anti fogs
