Subwoofer and Amplifier install
morgoth
Astra Model: Innovation 1.4 T 150hp
Astra Colour: Summit white
Re: Subwoofer and Amplifier install
Post by morgoth » Fri Sep 08, 2017 11:12 am
Johnny86 wrote:
Fri Sep 08, 2017 7:36 am
is it possible to just unclip the side panel without removing anything else?
Yes, the passanger side one is just clipped on, there's screw at the back on the driver's side panel.
Johnny86
Astra Model: 1.4T Hatchback 6 speed auto
Astra Colour: Coconut Brown (Dark Caramel)
Post by Johnny86 » Sat Sep 09, 2017 2:06 pm
got it , thanks.
JESSEGoTWood
Post by JESSEGoTWood » Wed May 16, 2018 7:32 am
Has anyone managed to find a 12v remote turn on wire in the rear or easier to obtain? Cheers
Sicknote1961
Post by Sicknote1961 » Wed May 30, 2018 11:46 pm
Would there be anyone willing to install an set of front speakers/amp/sub for me in my 66plate 1.6cdti elite?
for a few greenbacks plenty of tea and a few beers if your local:)
Im based in Bucks
cheers
Manta
Post by Manta » Sun Jul 08, 2018 10:31 am
How about those tweeters in dashboard?
Anyone know how to replace those, it's only 4 sets of speakerwires, shouldn't it be some sort of crossover installed? Or is it some sort of dsp in stereo, but regardless it's only 4 sets of speaker wires, anyone that have changed speakers and can tell how they did with the crossover that comes with the aftermarket speaker+tweeter sets.
josephdgould
Astra Model: '16 Holden Astra BK
Astra Colour: Cosmic Grey
Post by josephdgould » Sat Oct 27, 2018 10:02 am
Exactly what I've wanted to do to mine.. Thanks for the how-to!
I've been planning to (but haven't had the time) replace the factory speakers with something more punchy. I can't even get the volume up 3/4 without the speakers either cracking or becoming muffled/no punch. Have you upgraded your speakers too?
Pdwhelan
Astra Model: Astra K SRI VX-Line
Astra Colour: Blue
Post by Pdwhelan » Tue Oct 30, 2018 8:28 pm
I’m also wanting to know about the tweeters/mids in the dash, I haven’t taken anything out yet So can’t see how I would run a set of components with a decent cross over, unless a new wire can be run to the tweetes then the cross over can be tucked away under the dash.
Another issue would be the actual mounting of the tweeter, I pulled the grill off today to have a look and take pictures. Does anyone make adaptor rings for these or is it going to be a DIY?
bilboastra
Astra Model: Elite Nav 1.4T 150
Astra Options: None
Post by bilboastra » Tue Nov 06, 2018 9:06 pm
If I am just installing a KSC-SW11 Kenwood will a simple fuse tap/piggy back work ok for power and would I still need a remote wire power on wire if connected to an ignition switched fuse? :?
bilboastra
Astra Options: None
Post by bilboastra » Sat Dec 29, 2018 4:04 pm
Does anyone know what gauge these wires are, and do scotch lock/t-connectors work ok?
I cant see how I would connect into the plug as per the 1st post, what was crimped onto the end of the wires connecting in?
Enjoy
Post by Enjoy » Mon Dec 31, 2018 9:17 am
WOW!
Where is the fuse for the cigarette lighter/ 12v socket?
