Hi all, I have a 2016 Astra SRi with standard headlights. I don't like how yellow the standard bulbs look compared to the LED DRL's. Can anyone recommend an aftermarket bulb which matches the LEDs better?
There have been a few previous threads on this but either Phillips racing vision+150% or Osram nightbreaker laser seem to be the best choice,H7 for dipped,H1 for main.
Are these an easy fit or do you need strange double joint spindle fingers to fit them?
Trying to mind which of my previous cars you had to turn it on, crank the wheels right over and go in through the panel in the wheel arch. You needed arms twice the normal length.
I had mine checked and the headlights were pointing outwards and too much down. They were adjusted back to the mot limit. Technician said it was common with the Astra k that they weren't adjusted properly.
Mine were poor as delivered.... set far too low.
Adjusted up checked and now fine. Passed MOT ok.
89.7K posts
12.1K members
