Dashcam installation with pics of placement
Re: Dashcam installation with pics of placement
Post by danh23 » Wed Jun 13, 2018 1:32 pm
lucifer wrote:
Tue Jun 12, 2018 7:15 pm
I have A118c and hardwire kit with piggy-fuse. I want to use rear wiper fuse (found that some of you are using that fuse too), but I have no idea how many amp fuse should I use. Anyone could help please? Thanks.
The 20 amp (yellow fuse already in car) 2 amp (clear fuse was on the hardwire kit)
lucifer
Astra Model: K
Astra Colour: Royal Blue
Post by lucifer » Wed Jun 13, 2018 6:15 pm
thank you very much Image
Astra K 1.4 101PS Royal Blue
cdekepper
Post by cdekepper » Wed Aug 29, 2018 12:40 pm
I am trying to remove the centre console (phone holder) trim (no power bar) to hard wire a nextbase Dashcam. I understand the dash-fusebox is behind here. When I pull it, it bends and I don't want to break it. Do I need to use a trim removal tool, or have other members here managed to pull out the trim successfully, presumably with some force?
Post by danh23 » Wed Aug 29, 2018 2:08 pm
If you have the none powerflex bar then pull hard in left hand corner and it'll come out
cdekepper
Post by cdekepper » Wed Aug 29, 2018 3:49 pm
Brilliant - cheers
swaudby98
Astra Model: 1.0L Turbo SRi 66 Plate
Post by swaudby98 » Fri Aug 31, 2018 3:51 pm
Great guide, took about half an hour to get it fully wired and working. (y)
Black 1.0T (125BHP / 215Nm Torque)
Matte Black Alloys
5% Tinted Rears
Debadged
Nick Butler
Astra Model: 2017 SRi Nav EcoFlex S/S
Astra Options: Pretty standard I think
Post by Nick Butler » Sun Nov 04, 2018 11:37 am
danh23 wrote:
Tue Oct 10, 2017 3:30 pm
Here's my installation of dashcam
These pics were really useful, especially as my handbook says I have a fuse box in the glove box.
However I have piggy backed the same fuse, 5 along from the right on the bottom but the power is staying on to the camera with the ignition off.
Can anyone suggest another fuse that is not a permanent live?
SRi Turbo Nav EcoFlex - Summit White. S/S
Nick Butler
Post by Nick Butler » Sun Nov 04, 2018 5:06 pm
Sorted, needed to go 5th from left NOT right, DOH.
Dan
Post by Dan » Thu Dec 27, 2018 12:05 pm
Hi All,
Thanks for great advices, however under A pillar trim is located part of a curtain airbag.
Dash cam cable in front of the airbag can cause problem during the deployment, please have a look on the picture where a pillar is removed (just needs to be pulled out).
I would recommend to install dash cam cables behind curtain airbag where other cables are already installed by OEM...
Post by danh23 » Thu Dec 27, 2018 4:54 pm
Hi All,
Mine was put in by taking that piece of fabric off that's how I put these pics together
