Dashcam installation with pics of placement
Post by danh23 » Tue Oct 10, 2017 3:30 pm
Here's my installation of dashcam
Bottom row 5 in from the left
Where I have the earth cable connected
Underneath best to feed it through
Routed cable down then across
This can be pulled out from pulling from inside the car
To take this off need a trim remover tool
Cable under headlining
The placement of dashcam
Re: Dashcam installation with pics of placement
Post by astramaster » Tue Oct 10, 2017 9:06 pm
Good DIY. ;) Thanks for the pictures, it helps a lot.
Post by astramaster » Tue Oct 10, 2017 9:12 pm
Some questions....
- Is there communication between the fuse box and its back to pass the wires? (1st to 2nd photo)
- How do you remove the centre console's lateral plastics? (2nd photo)
- Is there any screw or just pull aside the A pillar? (6th photo)
Post by danh23 » Tue Oct 10, 2017 10:24 pm
Some questions....
The centre console part grab the bottom corner and pull they are held on by clips the A pillar same again but best using trim remover tools there held on by clips aswell
Post by astramaster » Tue Oct 10, 2017 11:46 pm
Thanks! ;)
What about: - Is there communication between the fuse box and its back to pass the wires? (1st to 2nd photo)
Post by danh23 » Wed Oct 11, 2017 12:01 am
That piggyback cable comes in the kit with the nextbase hardwire kit it has 2 piggyback cables 1 with small fuse in and the other with a big fuse it'll be the small fuse you will need for it
CraigW30
Astra Model: Design 1.6CDTi 110
Astra Options: Front & Rear Parking Sensors, CarPlay
Astra Colour: Graphite Grey
Post by CraigW30 » Sat Oct 14, 2017 4:24 pm
Which fuse did you tap into in the glovebox?
2016 1.6CDTi 110 Design
Granite Grey
Retrofit F&R Parking Sensors
Apple CarPlay Enabled
Post by danh23 » Sat Oct 14, 2017 4:27 pm
The fusebox in the centre console bottom row 5 in which is the rearwiper
Supermann25
Astra Model: MK7 Astra K Tech LIne 1.6 CDTI
Astra Options: Android Auto & Apple Carplay
Contact:
Post by Supermann25 » Thu Dec 07, 2017 5:52 pm
hey guys i just brought a dash cam and it comes with its own fuse to hardwire. it is not a piggyback fuse, but if i was to insert this in the rear wiper fuse socket will both the rearview wiper and dash cam still work? or do i need to cut and replace with a piggyback fuse
Also i can not find a right locate to get the wire to the fusebox in the centre console
sorry if this question has been asked before, i am a true novice when it comes to hardwiring and just reading into this lead me to buy this dash cam:
Pruveeo Hard Wire Kit for Dash Cam, Mini USB Port, 12V to 5V, DC 12V – 30V Car Charger Cable Kit
by PRUVEEO
Post by danh23 » Thu Dec 07, 2017 5:54 pm
by PRUVEEO
If you look at my pics of the installation you can see which fuse I used and both my cam and wiper works fine
