Fitting dashcam
Wykes123
Fitting dashcam
Post by Wykes123 » Sun May 02, 2021 4:33 pm
Need help fitting a nextbase dashcam. Using instructions I am using fuse 31 however no power goes through the cable to the dashcam even when ignition is on. Also when I remove the fuse the rear windscreen wiper still works. Any help?
astramaster
Re: Fitting dashcam
Post by astramaster » Sun May 02, 2021 6:05 pm
Sure you're using fuse 31?
Post a photo.
Wykes123
Re: Fitting dashcam
Post by Wykes123 » Tue May 04, 2021 12:18 pm
I am using the bottom row 5 in from the left
Valer
Astra Model: 2019 1.0 T SRi Nav Hatch
Astra Colour: Mineral Black GB9
Re: Fitting dashcam
Post by Valer » Tue May 04, 2021 2:03 pm
Yes that's F31DA, i've not played around with permanently fitting a dashcam yet,is that the recommended fuse to use for one then ?
it shows as being fed from the retained accessory power relay
Astra Sri 1.0t Hatch,Astra SRi 1.6t Tourer
Diagnostic kit.Opcom 2020,Mongoose pro GM2 running 2020 GDS2
Wykes123
Re: Fitting dashcam
Post by Wykes123 » Tue May 04, 2021 2:27 pm
Normally I’d try and use the one for the cigarette lighter but it’s too far in for the hardwire kit to work and looking at other people they use this one for it. However it doesn’t seem to power my dashcam. The strange bit is I pulled that fuse out and the rear wiper still works
Valer
Re: Fitting dashcam
Post by Valer » Tue May 04, 2021 2:35 pm
Are you looking for a permanent supply or a switched one ?
the wiper motor also has a main power feed (F48UA) from the wiper motor relay so it will still run.
Wykes123
Re: Fitting dashcam
Post by Wykes123 » Tue May 04, 2021 2:57 pm
Just for it to turn on when I turn the ignition on
Valer
Re: Fitting dashcam
Post by Valer » Tue May 04, 2021 3:05 pm
Have you had a m/m to check there's power at the fuse and also exactly when it goes off ?
i need to check exactly when power is supposed to be supplied from the acc relay but it looks ok to me plus it's been recommended to use.
here's the wiring diag
Re: Fitting dashcam
Post by Redman » Tue May 04, 2021 6:01 pm
That is the fuse intellilinkmods used for my reverse camera if I am not mistaken.
astramaster
Re: Fitting dashcam
Post by astramaster » Tue May 04, 2021 8:57 pm
That's strange.... :?
