Hi,
Is there anyone that have the number or picture for the Fixing of the Sideskirt on an SRI / OPC in the front wheelhouse?
regards
Fixing for SRI / OPC side skirt
- NIGHTCD
- Astra Model: 2018, 1,6T Automatic, Dynamic, OPC-Line
- Astra Colour: White
Re: Fixing for SRI / OPC side skirt
Anyone with an SRI or OPC Astra K that have the oportunity to take a picture of their side skirt in the front ? (Are on search for what fixing that are in the front wheel arch)
- Astra Model: 1.6 SRI VX Line Nav
- Astra Colour: Silver
I dont know if this is any good , I took this photo when I got the car as a write off before I repaired it
I have now just fitted mud flaps , so if I took a photo you would not see the end of the skirt, the end screw now go's through the flap skirt and liner
- NIGHTCD
Thanks, is the original fixing a washer and a bolt or in plastic?
Regards
Regards
The fixing is the same as used to hold the liner in place
A metal screw with an oversized head and small torx drive , in the body its a metal captive nut
I may be able to take a photo tomorrow
Its hard to see on this photo , its the same screw the use on a number of places on the liners
- NIGHTCD
Thanks for the update an picture
