Installing leather seats
I have the Astra K 1.4 Turbo VX LINE NAV, would I be able to to install the elite NAV leather seats with the functionality of heated seats etc ? Is it possible?
- Astra Model: 1.6 SRI VX Line Nav
- Astra Colour: Silver
Re: Installing leather seats
Yes I have just done it
I had to put in a bit of wiring and change the the heater control panel and the armrest panel and loom
But I am waiting for lockdown to lift so I can have the Vci coding done
So they are in and connected but not yet working
Thanks for you reply; how much has it cost you so far ?
I got the seats for a bargain price of £300 from a local scrapyard, they came with door cards centre consul and heater controls all from a late 2019 car
The programming should cost about £100 -£120 from a non dealer Vauxhall specialist
The wiring I have done myself
The controller for the front seats is under the passenger seat ,it need power from the centre fuse box , a data wire from the BCM and six wires between the seats
The controller for the rear is under the cushion ,it needs power from the rear fuse box a data wire from the same point as the fronts and about 4 wire from the BCM to the switch's
Some cars may have some of the wires in already , I have a late 2018 and it didn't
People like JRC Vaux Works are very helpful and would do the job for you , or I think they can make the wiring loom up for you to fit
Hi I'm just about to purchase a leather interior and fit into my 17 sri, I don't have any options for heated seats will that be an issue with fitting them I also noticed there is 2 buttons on the drivers right hand side my current seats don't have they buttons what are they for and would they work with my current wiring harness any information would be great
The two buttons sound like the tilting of the seat cushion. They probably also have a lumbar button in the raising/lowering handle.casuk wrote: ↑Tue Apr 06, 2021 8:58 amHi I'm just about to purchase a leather interior and fit into my 17 sri, I don't have any options for heated seats will that be an issue with fitting them I also noticed there is 2 buttons on the drivers right hand side my current seats don't have they buttons what are they for and would they work with my current wiring harness any information would be great
If you don't need the heating, you can just plug in the new seats. If you want the heating, you'll need to run additional wires, get a heating module, get a new climate panel with heating buttons and program the BCM. It's definitely doable.
Astra K 1.6 CDTi. Mods: AGR seats, 360° 3D camera, SeatSkinz, heated armrest and rear seats, dynamic turn signals, footwell and glovebox lights, light under boot floor, gear surround ambient light, pedalbox, wood-look trim and black felt interior.
Cheers mate I'm just going to put them in as is no modifications I'll just have to live without the heat and lumbar for now anywayGunde wrote: ↑Wed Apr 07, 2021 7:45 amThe two buttons sound like the tilting of the seat cushion. They probably also have a lumbar button in the raising/lowering handle.casuk wrote: ↑Tue Apr 06, 2021 8:58 amHi I'm just about to purchase a leather interior and fit into my 17 sri, I don't have any options for heated seats will that be an issue with fitting them I also noticed there is 2 buttons on the drivers right hand side my current seats don't have they buttons what are they for and would they work with my current wiring harness any information would be great
