OBDLink MX (or elm327), Instrument Cluster, hidden menu
astramaster
Re: OBDLink MX (or elm327), Instrument Cluster, hidden menu
Post by astramaster » Thu Mar 25, 2021 2:36 pm
frank appleton wrote:
Sat Mar 13, 2021 8:05 pm
That is great news.
Can you share where you got it from and what make is it.
Thank you.
Astra944444 wrote:
Sun Mar 21, 2021 5:35 pm
I am also interested
I bought vLinker MC+ here: https://bit.ly/3clLtLB ;)
Crakatoa
Post by Crakatoa » Sat Mar 27, 2021 8:53 pm
Hi,I bought a vLinker MC+ on Amazon,It connect perfectly to GMprog app and works with GMprog website. I only have a question to do, when i go to IPC configuration how i save the changes ?
For example I select to add the turbo gauge on the display,than what I do to make this work?
I got a 2020 Astra k with digital tacho
gmprog
Post by gmprog » Sun Mar 28, 2021 8:17 am
1. do not understand "save"
made changes. you can "save" - in case of backup
2 chose what to record
3 write .
Crakatoa
Post by Crakatoa » Sun Mar 28, 2021 1:31 pm
3 write .
So in this case i used the A3 menu,I have to leave on just the A3 or all the records?
If I made a backup saving,I have to write particular numbers or what I want?
Sorry for all this questions but the website isn't really clear, also russian and english are not my main languages,hope you understand :D
lhb
Astra Model: 2017 ST 1.4T AT6 Innovation
Post by lhb » Mon Mar 29, 2021 8:43 pm
Hi,
I tried to connect using OBDLink MX, but I got an error after I enter APK ID and connect. Use blocks IPC ELM327
gmprog
Post by gmprog » Tue Mar 30, 2021 10:11 pm
Hi,
ignition ON?
lhb
Post by lhb » Wed Mar 31, 2021 9:25 am
Yes ignition is on. I'm able to retrieve data when selecting BCM and ECU but IPC fails
nulda
Post by nulda » Wed Mar 31, 2021 9:38 am
Hi, I get error after connect with APK ID too. "Could not get data from server".
I use modified ELM327. Ignition ON,
Gunde
Post by Gunde » Wed Apr 07, 2021 2:50 pm
So, those of you who used this, what were you able to do? Anything besides activating additional screens in the midlevel display?
Astra K 1.6 CDTi. Mods: Top level leather seats w/AGR, 360° 3D camera, heated armrest, dynamic turn signals, footwell and glovebox lights, light under boot floor, gear surround and door ambient lights, pedalbox, wood-look trim and black felt interior.
gmprog
Post by gmprog » Thu Apr 08, 2021 10:14 pm
nothing else is possible :lol:
