OBDLink MX (or elm327), Instrument Cluster, hidden menu
Re: OBDLink MX (or elm327), Instrument Cluster, hidden menu
I tried to do the procedure as in the video on my astra k but it tells me that the server is down
- astramaster
Astra944444 wrote: ↑Sat Dec 26, 2020 6:48 pmI tried to do the procedure as in the video on my astra k but it tells me that the server is down
What OBD tool did you use?
- astramaster
Modified Elm327 ?
Yes there is.astramaster wrote: ↑Fri Dec 25, 2020 10:21 pmWith GMProg, does it get the option ticking menu like 1:52 ?
check out my last post on facebook. we made a list.
can anyone have a vLinker ?
maybe it will work with the IPC
it costs about half as much as the OBDLink MX
not modified
so i have to buy either usb els27 or an odblink mx
Will it work with that?
https://a.aliexpress.com/_mrEe27X
if you need to work with a IPC, you need a GMLan
the GMLan is only in the ELS27 orig. and obdlink mx
perhaps. the GMLan is in other devices. We do not know. read the instructions for the device.
no. only orig.
