Wiring from engine bay to passenger footwell
joexn
Post by joexn » Mon Nov 16, 2020 4:37 pm
Does anyone know the best way to get a couple of 2-core cables from the engine bay to the passenger footwell (behind the glovebox)?
I've previously run then by the passenger door and straight behind the passenger airbag switch panel but I want a more permanent hidden solution. I'm open to any suggestions or ideas but would prefer not to drill – but if it's the only way, I'm open to advice.
All the best.
Philich
Astra Model: 1.6 SRI VX Line Nav
Astra Colour: Silver
Re: Wiring from engine bay to passenger footwell
Post by Philich » Tue Nov 17, 2020 11:31 pm
If its anything like the drivers side
If you remove the the wheel arch liner there should be a plastic grommet which takes you through to the passenger compartment,
It should be just a case of pushing it out ,then put a hole through it and putting it back
I did this to fit a parking sensor on mine
