Oil 1.0 105
Astra944444
Oil 1.0 105
Post by Astra944444 » Fri Nov 06, 2020 10:49 am
hello i have engine 1.0 105 b10xfl le1 from 2016 is i would like to do the oil change myself
my current motor oil is dexos1 gen2 5w30
i have read on the forum now with the new specification 0v0401547
my question is do i continue in 5w30 or 0w20?
sorry if the subject was brought up, I did not understand correctly
Crosseyxpower
Astra Model: Sri nav
Re: Oil 1.0 105
Post by Crosseyxpower » Fri Nov 06, 2020 11:19 am
It doesn't really matter which one you choose to use, but use the newer 0w20👍
The servicing is pretty easy to do, just make sure you have a tidy oil wrench as the oil filter is tight against the sump limiting access to it.
Astra944444
Re: Oil 1.0 105
Post by Astra944444 » Fri Nov 06, 2020 1:16 pm
thanks toi
what is the difference of the two oils
Crosseyxpower
Re: Oil 1.0 105
Post by Crosseyxpower » Fri Nov 06, 2020 1:56 pm
thanks toi
Its viscosity at colder temperatures.
Astra944444
Re: Oil 1.0 105
Post by Astra944444 » Fri Nov 06, 2020 3:07 pm
i will use 0w20 is there an opel reference
http://www.opel-niedersachsen.de/oel.html
I just ran into it, it's my b10XFL motor which is part of the dexos 1 gen2 in 5w30
This is the b10XFT motor which has 0w20
Astra944444
Re: Oil 1.0 105
Post by Astra944444 » Wed Nov 11, 2020 6:48 pm
I just ran into it, it's my b10XFL motor which is part of the 0w20
Astra944444
Re: Oil 1.0 105
Post by Astra944444 » Thu Nov 12, 2020 4:43 pm
sorry do you know this brand of MANNOL oil because i find it really cheap
Re: Oil 1.0 105
Post by Redman » Thu Nov 12, 2020 7:21 pm
Dont know of that oil but it is ILSAC GF5 and I think it needs to be ILSAC GF6. They have modified oil by quite a degree I believe. Not just for lspi prevention but also for higher vapour temps and improved timing chain anti wear ability. Backwards compatibility on some engines is an issue.
https://www.mobil.com/en/lubricants/abo ... ilsac-gf-6
Astra944444
Re: Oil 1.0 105
Post by Astra944444 » Thu Nov 12, 2020 8:17 pm
Yes is ILSAC GF5
Re: Oil 1.0 105
Post by Redman » Thu Nov 12, 2020 9:14 pm
I myself would not use that oil you have pictured as it does not meet vauxhall/opel present standards recommended for your engine. They list 0V0401547 0W20 as mandatory to use for servicing your engine.
