Digital tacho from insignia fitted and working
Milos1989
Re: Digital tacho from insignia fitted and working
Post by Milos1989 » Sun Jan 24, 2021 8:51 pm
Can anyone help me with programming a 8 inch digital cluste on an insignia?
gmprog
Post by gmprog » Mon Jan 25, 2021 9:54 am
remotely? (teamviewer)
Milos1989
Post by Milos1989 » Mon Jan 25, 2021 10:42 am
Yes. I managed to connect the board installation for work, but now it needs to be programmed. Vci file modifier required. I have j2534 pass-thru tool.
gmprog
Post by gmprog » Mon Jan 25, 2021 11:26 am
what device do you have? device working with GM_LAN?
Milos1989
Post by Milos1989 » Mon Jan 25, 2021 11:50 am
Vxdiag
gmprog
Post by gmprog » Tue Jan 26, 2021 3:54 pm
Vxdiag
you give us a week to prepare
Astradriver1983
Post by Astradriver1983 » Sun Jan 31, 2021 12:01 pm
After i Put of the Battery an Push the Igniotion on comes on tjhe left side another Display.
Andymrowell
Post by Andymrowell » Wed Feb 24, 2021 12:54 pm
I'm just in process of changing some modules in astra k. Wondering if anyone could help with programming my vin to a replacement instrument cluster. Part number is exact match. I have working vxdiag on laptop but no sps login. Could someone do this remotely for me over teamviewer?
kirikoo
Post by kirikoo » Sun Mar 21, 2021 10:03 am
Hello everyone,
I've read the whole thread, but can't get a real idea of what's really needed to retrofit a digital (insignia or new astra k) cluster into my actual astra with analog cluster.
I have an astra k innovation with navi900, joystick buttons like steering wheel.
Can someone tell me appart from buying the digital (which i'm intending to do) what other stuffs do i need? like cables, obd adapter and more important, who can help and assist me in programing and making it work. I really don't want to spend 300 euros in that cluster to be left with either not able to use it or worst having mounted the cluster and just getting a useless screen with no information or less than the actual one.
Thanks a lot in advance
pepe
Post by pepe » Sun Mar 21, 2021 12:33 pm
The unit is plug and play, no need to modify cables, plugs or anything else. You only need to get it programmed to your car. If you have the proper cable and software this can be done remotely. The other option is send the unit over or visit someone who can program it for you.
