wireless charger
- Astra Model: 2016 Astra K 1.6 110HP
- Astra Colour: Asteroid Grey
wireless charger
So, the 2019 onwards Astra's has wireless charging.
But is it only the models with electric handbrake ?
Have seen pictures of where to put the phone to charge, but only seen it with electric handbrake.
Have just gotten a phone that supports wireless, and was wondering if it would be possible to buy a new centre console part, where the charger is and swap it out with the one i have now. Manual handbrake though.
Re: wireless charger
Do you not use CarPlay/Android Auto?
AFAIK this rules out using wireless charging
Depends....If i am driving to work i dont use it, the trip is only 20-25 minutes and the car almost knows the way all by itself, but it would be nice to be able to just pop the phone in the hole and it would charge.MisterEChops wrote: ↑Mon May 18, 2020 2:25 amDo you not use CarPlay/Android Auto?
If the phone is low on power i usually top it up a bit on the way home, but me being a bit of a forgetful guy, i usually remember that it needs a charge, after i drive off, and it would be great to be able to just pop it in the hole and not have to deal with the wire in the armrest and trying to put the USB plug into the phone.Not to mention, that would be seen as "using a mobile device while driving" (yes, you only need to hold it in your hand) and this is illegal. If i could take it out of the pocket and put it into the charger hole, it would not be an offence
Also, the day google releases their "chromecast" device for AA, and you just plug it into the USB and you have Android Auto Wireless, the wireless charger will be a great feature, you dont need to fiddle with wires ever again in the car
Keep in mind, the USB port in the Astra is very low amperage... so at best wireless charging is going to be slowastraowner wrote: ↑Mon May 18, 2020 8:13 pmDepends....If i am driving to work i dont use it, the trip is only 20-25 minutes and the car almost knows the way all by itself, but it would be nice to be able to just pop the phone in the hole and it would charge.MisterEChops wrote: ↑Mon May 18, 2020 2:25 amDo you not use CarPlay/Android Auto?
I have 2 charge ports and they both support 1½A charge, the charging current has nothing to do with the USB in the radio as such, it is dependent on the charge circuit inside the part you plug your phone into.MisterEChops wrote: ↑Wed May 20, 2020 1:03 amKeep in mind, the USB port in the Astra is very low amperage... so at best wireless charging is going to be slow
Also, the wireless charger will be feeding off of the 12V supply in the car and have it's own charging circuit to support whatever charging current it will be able to.
My phone supports proprietary 30W wireless charging and 10W QI, and if i could just get 10W QI charging it would be great. This is what i have at my bedside, charging the phone every night.
Ah yeah, as I suspected then. 1.5A is pretty slow charging.astraowner wrote: ↑Wed May 20, 2020 3:21 pmI have 2 charge ports and they both support 1½A charge, the charging current has nothing to do with the USB in the radio as such, it is dependent on the charge circuit inside the part you plug your phone into.MisterEChops wrote: ↑Wed May 20, 2020 1:03 amKeep in mind, the USB port in the Astra is very low amperage... so at best wireless charging is going to be slow
Sure you can plug your own car charger in so that you can use the wireless charger, but that’s already more effort than just plugging your phone in to the existing setup. Doesn’t make a lot of sense.
1.5A is 15WMisterEChops wrote: ↑Thu May 21, 2020 12:54 amAh yeah, as I suspected then. 1.5A is pretty slow charging.
My Oneplus 3 that i had until very recently was able to do "Dash Charging" at 18W
The new Iphone SE apple just released is also 18W
I just checked, my daughters huawei is 18W, my wife's pocophone is 18W, my son's Samsung A20e is 15W charge.
You may call 15W charging slow, but honestly, 15/18W is the "speed limit" for a LOT of phones today.
I now have a Oneplus 8 Pro, it is capable of 30W charging, but still it is being charged, using a 10W QI charger on the table by my bed.
Unless you are a 15 year old teenager with the phone glued to your hand, that get the shakes whenever the phone leaves your hand, this is not going to be a problem if it is "only" charged at 15W.
No matter what phone you get, it will only charge at about 15W, from 80-100% anyway.
Nope, 1,5A = 7,5W. Charge voltage is 5V.
Still does not matter, 1,5A is plenty enough for most users
- Astra Model: 1.4 150PS Enjoy (Danish spec), Hatch, 16.5
- Astra Colour: Power Red
You need to know the voltage, you can't just "translate" amps to watts.
If it's a standard 5v, as per USB spec, then it's 7.5w. Some wall chargers ramp the voltage up as well, but they need to negotiate with the phone to do so, and there are different standards (Qualcomm QuickCharge, Mediatek Pump Express, blah blah blah). USB-C power delivery is a whole other question, but since the port is type A, then it's going to likely play it safe and just deliver 5v.
That's pretty decent in my books, I'm pretty sure the earlier models (like mine) have an even weaker USB port
- NIGHTCD
- Astra Model: 2018, 1,6T Automatic, Dynamic, OPC-Line
- Astra Colour: White
Will reckon it will be sutable to buy a new center console or parts, there is an control module for the QI charger.astraowner wrote: ↑Fri May 15, 2020 11:45 amSo, the 2019 onwards Astra's has wireless charging.
Do you know the partnumber? (Looking for the mod myself)
Regards
