Hello I got an astra k 6speed auto 1.6 cdti and was wondering would the insignia flat bottom steering wheel would fit to an astra ?
Hello, it is not to complicated, it is two holes on the rear where you have to insert an skrewdrivet (small) and you have to pull in the airbag (becase it is tight) and an torx skrew that you must remove . And finaly the wiring must changed (easy, fix (because the airbag connector is diffirent))Gunde said:How complicated is the swap?
Reckon it is the same steering wheel, have fitted it an i am living in Norwaypepe said:Would anybody have a partnumber for all of us overseas?
Whats the part number youve used if you dont mind me asking.NIGHTCD said:Reckon it is the same steering wheel, have fitted it an i am living in Norway
Se the attached pictures in the topic, maybe you find someting therepepe said:Whats the part number youve used if you dont mind me asking.NIGHTCD said:Reckon it is the same steering wheel, have fitted it an i am living in Norway
Tried without succes, you got it of eBay too, that link cornish posted?NIGHTCD said:Se the attached pictures in the topic, maybe you find someting there
Yespepe said:Tried without succes, you got it of eBay too, that link cornish posted?NIGHTCD said:Se the attached pictures in the topic, maybe you find someting there
Yes, will take a few seconds to do itpepe said:Bit the bullet and ordered the wheel. I have to swap over the loom as I dont have a heeted wheel now. When swapping over, is it a plug and play job?
Damn you, I was just about to! :lol:pepe said:Bit the bullet and ordered the wheel. I have to swap over the loom as I dont have a heeted wheel now. When swapping over, is it a plug and play job?
If you message the ebay seller he'll list another one. When I spoke to him he had several availableGunde said:Damn you, I was just about to! [emoji38]pepe said:Bit the bullet and ordered the wheel. I have to swap over the loom as I dont have a heeted wheel now. When swapping over, is it a plug and play job?
Exactly what I did.cornishtaz said:If you message the ebay seller he'll list another one. When I spoke to him he had several available
Just disconnect -ve leave for a couple of minutes then all will be safepepe said:Got the wheel. Planning on fitting it somewhere next weekend. When removing the airbag, disconnecting the battery in the boot is enough to not get headbashed by the airbag, or is there something else I should know/do?
Pull [emoji16] it is glued onpepe said:Halfway there. Any tricks on undoing that torx screw, its tight as sh*t.
