Auto lights disabling
Re: Auto lights disabling
Post by cornishtaz » Sat Jan 13, 2018 10:20 am
oastra wrote:cornishtaz: thank's a lot !
both references are "compatible", as you said previously: "auto levelling one" ?
is this UK specific (steering wheel on the right) or symetric (could be use with left or right stering wheel) ?
have a nice day
For LHD cars part numbers are
13470444 for rear fogs only
13470446 for front/rear fogs
Auto levelling is for cars with Intellilux headlights but there is no equivalent Corsa switch
Sent from my SM-G930F using Tapatalk
oastra
Post by oastra » Sat Jan 13, 2018 10:36 am
great, but outch for IntelliLux.
I miss-undestand you find one:
"So all you need to do is buy the correct Corsa E switch( auto levelling one is proving difficult to find)"
So you don't find any reference on Corsa E... anyway on other IntelliLux cars: Insignia, GrandLand or whatever ? :?
it's only cosmectic reason, so the one with manual leveling will work correctly or not ?
(I suppose auto-leveling is not manage by the switch itself, but one of the ECU in the boot/car ??)
OastrA
Post by cornishtaz » Sat Jan 13, 2018 10:52 am
I need to check a manual leveling switch to make sure the auto leveling overrides the manual side.
The Insignia switch would require modifying similar to a Astra J switch.
oastra
Post by oastra » Sat Jan 13, 2018 11:28 am
If manual leveling is not a problem for auto leveling management, could the front face be replaced with the original to mask unwanted wheel ?
OastrA
Post by cornishtaz » Sat Jan 13, 2018 11:39 am
oastra wrote:If manual leveling is not a problem for auto leveling management, could the front dace be replaced with the original to mask unwanted wheel ?
I need to check but can't see any reason why not
+astraman+
Astra Model: 1.0 SRi Nav
Post by +astraman+ » Sat Jan 13, 2018 11:51 am
cornishtaz wrote:
Sat Jan 13, 2018 10:01 am
oastra wrote:Scotty, corni: combo ! Thank's !
Will see to do that if changing light is easy...
Swapping the switch is easy
1. Open small glovebox under switch
2. Squeeze the back edge together so it can be lowered fully.
3. Reach up behind switch and push it out
4. Unplug elec connector and swap over switch.
If you want to swap the leds in the switch from red to white you need to remove the pcb and swap the smd leds (these are about 3mm in size) marked in pic below.Image
Did you swap out the LEDs on yours? looks a proper fiddly job!
Post by cornishtaz » Sat Jan 13, 2018 2:44 pm
Yes mate did mine as I used to do Astra J led conversions yes can be fiddly due to size
Post by Scotty_b » Sat Jan 13, 2018 4:50 pm
Bought another switch today for £20. Are the leds 3528s?
Post by cornishtaz » Sat Jan 13, 2018 6:22 pm
Scotty_b wrote:Bought another switch today for £20. Are the leds 3528s?
You can use 1206 or 0805
oastra
Post by oastra » Sun Jan 14, 2018 9:50 am
How much leds do I need to replace please?
OastrA
