Navi 900 IntelliLink
krenkel
Re: Navi 900 IntelliLink
Post by krenkel » Sat May 12, 2018 9:41 am
For a long time I did not go here
I need a car VIN for analysis and programming capabilities
If you want to install a DAB system, then you need to replace the SilverBox radio unit and program it. There is nothing complicated in this.
He is most likely behind the glove compartment
Which block do you want to put? Tell me his number. We put 2 different blocks with DAD 4505 and 6166
Choose any, but I advise you to 6166. He has a newer reception system
Martin9876
Post by Martin9876 » Sat May 12, 2018 4:20 pm
My satnav voice commands have stopped working. The map display is working and i have checked the volume and is set to 30%.
Any idea?
If i use Waze or Google Maps the voice command works fine.
Bazviv
Post by Bazviv » Mon Jul 09, 2018 10:32 am
My old 2013 ford focus Titanium X had showed speed limits. Also alert tone for safety cameras.
Raantje
Astra Model: Astra Sports Tourer 1.4 Innovation 150pk
Astra Colour: Zilver , metallic
Contact:
Post by Raantje » Wed Jul 11, 2018 9:15 pm
Hello Krenkel, excuse for my bad English, I am a Dutchman and do not write so often in English.
My Astra does not support DAB+ reception and I would like to. If I understand correctly, is it sufficient to replace the radio tuner (SilverBox behind the glove compartment) with a new radio tuner with DAB + support? Type DAD 6166 and in this tuner a VIN Code must be programmed. Do you need a random VIN code from an astra with DAB+ support or do you need the VIN code of my own car? Does something have to be released in the software in the car itself? And, is the DAB + antenna cable present behind the glove compartment or should this still be pulled forward from the rear window.
And not unimportant, what is this going to cost?
ziggyturbo
Astra Model: Innovation 1,4T (110 kW) HB
Astra Options: Intellilux;Intellilink;18" Bicolor;DAB+;Keyle S/S
Post by ziggyturbo » Thu Jul 12, 2018 10:41 am
Goeiemoggel Raantje....
Why don't you ask your local Astra-dealer about the possibilties to upgrade your radio to DAB+.
Greetz from Holland !
Raantje
Contact:
Post by Raantje » Thu Jul 12, 2018 1:55 pm
Hoi ziggyturbo,
I have asked the local opel dealer but according to him this was not possible. I drive in an imported Astra from Spain, of course he is not happy with that. The Dutch government causes this parallel import because of the high tax on cars. But there is no DAB + on the spanish astra.
Ivanzu
Astra Model: 1.4T
Post by Ivanzu » Thu Jul 12, 2018 7:50 pm
It was available but only at extra cost.
Post by astramaster » Thu Jul 12, 2018 9:06 pm
Why don't you ask your local Astra-dealer about the possibilities to upgrade your radio to DAB+.
They will say "No, that's completely impossible" because they know it's easier than "Yes, but we do not know how to do it". :roll:
pepe
Post by pepe » Fri Jul 13, 2018 9:25 am
Hoi ziggyturbo,
I have asked....
Wouldnt be too fussed about missing out Dab. Yes the quality is slightly better, but at cruising speed I doubt if you’d notice the difference.
