Advise on Engine Bay clean!
AC2019
Astra Model: Astra SRi NAV 1.6 CDTI (136)
Astra Options: 18" Colour Alloys, Driving Asistance Pack.
Post by AC2019 » Wed Jan 22, 2020 9:46 pm
I want to tackle giving the engine bay a deep clean.
What products do you recommend?
What's the best process to do it?
Cheers,
Vauxhall Astra SRi NAV 1.6 CDTi (136).
Summit white. 18" Bi-Colour Alloys, Driving Assitance Pack. Light and Sight Pack.
Plated 2016. Mileage (25k/yr)
Corbil
Astra Model: 1.6 Cdti Innovation 136bhp
Re: Advise on Engine Bay clean!
Post by Corbil » Thu Jan 23, 2020 1:07 pm
Something like this is in your preferences?
Before
After
AC2019
Post by AC2019 » Sun Jan 26, 2020 12:04 pm
Before
After
That looks amazing! Yes!! How did you do that??
Corbil
Post by Corbil » Sun Jan 26, 2020 6:14 pm
Dear friend,
I used the Μeguiars AIO (all purpose cleaner, 1 part of AIO and 4 parts of water). You can use whatever brand you like....More or less every brand does the job.
The procedure is first to get rid of the dirty parts with the help of the AIO and a brush until no dirt stays at your brush. By using a microfiber towel dry off the surfaces after spraying and rubbing.
Second and final step is to apply a sealant coat of the 303 aerospace with a clean microfiber towel. Aerospace gives a natural look at your plastic surfaces. For better shine and restoration (if your plastic parts are faded) use the gel coat of Chemical guys, the so called Tire & Trim Gel and you will get the result you see at the above picture.
What ever you can get rid of from the bay of the engine, like the air intake, the engine cover etc, in order to give you more hand to deeper areas, will make your life easier.
Be patient and this will give you a better result.
AC2019
Post by AC2019 » Wed Feb 05, 2020 9:20 pm
Dear friend,
Thank you!! When I finish I'll post a pic!
