QUICK HEATING FOR ASTRA K
Re: QUICK HEATINF FOR ASTRA K
Post by astraowner » Tue Apr 28, 2020 2:26 pm
ROBINHOOD wrote:
Mon Apr 27, 2020 8:31 pm
astraowner wrote:
Mon Mar 23, 2020 1:56 pm
880PEL wrote:
Mon Mar 23, 2020 8:15 am
There are no active shutters on my 1.6T.
I would like that, i know Robinhood has added it to his car, but i dont know if it will be possible to retrofit and make it work on a 2016 astra.
I would not think a 2016 is ready, software wise ?
Yazılımı hala temin edemedim :(
So you can not update the software ?
Does your shutters not work then ?
ROBINHOOD
Astra Model: 1.6 CDTI SPORTS TOURER EXCELLENCE
Astra Options: AGR + SUNROOF + 18'' STEEL RIM + NAVIGATION + F1
Astra Colour: WHITE
Post by ROBINHOOD » Fri May 08, 2020 9:53 am
evet hala çalışmıyor. opel program sağlayamadı :(((
ASTRA K SPORTS TOURER 1.6 CDTI 136HK AT EXCELLENCE + NAVI900 + AGR + 18" BICOLOR RIM + SUNROOF + SPORT FUNCTION + AIRWILNESS + INTELLILUX LED MATRIX HEADLAMP + F1 STEERINGWHEEL + GHOST SPEEDOMETER
Post by astraowner » Wed Jun 10, 2020 2:31 pm
Bummer, but i would say it was to be expected, they dont like people retrofitting stuff. :roll:
Mikhail8815
Post by Mikhail8815 » Tue Feb 16, 2021 9:20 am
ROBINHOOD wrote:
Sun Mar 22, 2020 9:27 am
It is no longer a problem to warm up in my diesel car.
Whether your engine temperature is as cold as I want, I can heat the cabin in 40-50 seconds.
Hello. Sorry for my English, I am writing with the help of a translator. Did you have to pull the power cable into the engine compartment yourself to install the heater? Did you use a 100 Amp fuse to connect the red wire? Thank.
ROBINHOOD
Astra Colour: WHITE
Post by ROBINHOOD » Sat Feb 20, 2021 2:52 pm
Where do you write?
Mikhail8815
Post by Mikhail8815 » Sun Feb 21, 2021 3:20 pm
Where do you write?
I'm from Belarus. I want to install quick heat just like you do. There is no problem to buy this electric heater. But it's not clear to me if you had quick heat power leads in your car? Or did you have to run the wires from the engine compartment to the passenger compartment yourself? Also for quick heat a 100A fuse is required. Have you installed it?
ROBINHOOD
Astra Colour: WHITE
Re: QUICK HEATING FOR ASTRA K
Post by ROBINHOOD » Tue Feb 23, 2021 5:23 am
what is your car ?
Mikhail8815
Post by Mikhail8815 » Fri Feb 26, 2021 8:52 am
what is your car ?
Opel Astra K 2016
Mikhail8815
Post by Mikhail8815 » Fri Feb 26, 2021 9:11 am
what is your car ?
I checked the presence of power leads for the electric heater. There are no wires in the car. at least they are not visible under the hood, as well as under the driver's floor. You will have to lay the wires yourself. It is also necessary to activate the presence of qh using mdi.
ROBINHOOD
Astra Colour: WHITE
Post by ROBINHOOD » Fri Feb 26, 2021 2:16 pm
так как установки нет, ее следует переставить согласно директивам. Я могу подключиться к вам удаленно и установить программу.
