QUICK HEATING FOR ASTRA K
- ROBINHOOD
- Astra Model: 1.6 CDTI SPORTS TOURER EXCELLENCE
- Astra Colour: WHITE
It is no longer a problem to warm up in my diesel car.
Whether your engine temperature is as cold as I want, I can heat the cabin in 40-50 seconds.
ASTRA K SPORTS TOURER 1.6 CDTI 136HK AT EXCELLENCE + NAVI900 + AGR + 18" BICOLOR RIM + SUNROOF + SPORT FUNCTION + AIRWILNESS + INTELLILUX LED MATRIX HEADLAMP + F1 STEERINGWHEEL + GHOST SPEEDOMETER
- ROBINHOOD
Re: QUICK HEATINF FOR ASTRA K
CONTINUED PHOTOS
Well done!
However, QuickHeat has been standard for all nordic region Astra diesels and since 2018 standard for ALL Astra K range.
I have it on 1.6T and it sure helps defrosting
Is anywhere mentioned it´s power?
- Astra Model: 2016 Astra K 1.6 110HP
- Astra Colour: Asteroid Grey
I have a 2016 diesel astra and i live in the nordic region so supposedly i have the quick heat, but on a cold day with sub zero temperatures celsius, it takes more than 45 seconds to get the windscreen free of moisture.
Is the 45 seconds, a bit optimistic or is my car not equipped with this anyway or maybe it is broken ?
Does it come on automatically and can i see somewhere, that it is actually on and will the car know that it is faulty if it is ?
- ROBINHOOD
If output number 7 in the fuse box under the hood is full, you have qh.
- ROBINHOOD
Do you have a active air grill shutter ?
45 sec is extremely well done! No need to worry about that.
Just think of household heater. For example 1,5kW heater takes quite a lot time to heat up.
Quick Heat is perhaps around 600W (40+A)?
There are no active shutters on my 1.6T.
I do have something on clamp 7 as shown above.
I would like that, i know Robinhood has added it to his car, but i dont know if it will be possible to retrofit and make it work on a 2016 astra.
I would not think a 2016 is ready, software wise ?
- ROBINHOOD
Yazılımı hala temin edemedimastraowner wrote: ↑Mon Mar 23, 2020 1:56 pmI would like that, i know Robinhood has added it to his car, but i dont know if it will be possible to retrofit and make it work on a 2016 astra.
