Astra K rear turn indicator LED modification (no error)
FunkyRider83
Astra Model: K SRI VX 1.6T
Astra Colour: Silver
Re: Astra K rear turn indicator LED modification (no error)
Post by FunkyRider83 » Sun May 26, 2019 10:57 am
UPDATE:
After some more trial and error, I am able to increase the load resistor from 15Ohms to 25Ohms. It still works without triggering bulb out warning, and the long term load temperature I am now a lot more comfortable with.
When ordering the load resistors, choose 25W, 25R as new values. It will work better by reducing waste energy / heat by 40%.
The testing step by multi-meter will also have a different value, from around 13Ohm to around 24Ohm.
Matt9817
Astra Model: SRi
Astra Options: Parking Pack
Post by Matt9817 » Wed Jun 05, 2019 1:41 pm
Done this myself, very easy to do and results are excellent. FunkyRider - do you think using the 25W 25ohm resistor is essential? I have mine set up with the 25w 15ohm one you recommended earlier.
FunkyRider83
Post by FunkyRider83 » Wed Jun 05, 2019 11:21 pm
Well done Matt! Good to see others having success using this tutorial. The difference between 15 and 25 ohm resistors is the 15 ohm one burns extra 4w when on. Not a significant amount, just a nice to have thing to reduce the power consumption, hence heat. After using the 15 ohm config for 3 months there was nothing wrong when I took them out. I just wanted to see how much I can push the bulb out detection circuit while reducing heat.
The original incandescent bulb burns 16W, LED with 15 ohm load resistor burns 14W, LED with 25 ohm load resistor burns 10W, all without triggering bulb out error. I also tried 33 ohm resistor but that one will give errors so I think 25 ohm is as much as I can push it.
Bonarius
Post by Bonarius » Tue Jun 11, 2019 12:41 am
Thanks for your well explained tutorial! After long research I have to acknowledge the fact there is no plug&play bulb on the market, whatever a seller is promising. The only way to make this work is to make my hands "dirty". I will give this a try shortly.
Post by astraowner » Tue Jun 11, 2019 6:37 am
If you look at the, quite physically large resistor that he needs to add, it becomes evident that such a bulb would not be possible to make as a plug&play part.
The stupid thing here is that it would be easy for Vauxhall to make a variant setting that omitted the bulb check but as far as i know they never did.
How difficult would it have been to make a variant coding "Filament / LED" to be able to disable the check and warning.
If EU passes a law that says that LED bulbs can be used as replacement, you would still need to use a filament bulb or a LED and a resistor.
If they pass such a law it would probably be to save fuel, but this method saves no fuel as the saved energy is wasted in a resistor to make the car "happy"
AussieKOwner
Astra Model: RS 1.6T
Post by AussieKOwner » Sun Jul 07, 2019 10:52 am
I tried this mod with 25 Ohm resistors and still get warning messages but not every time I turn on indicator.
Bonarius
Post by Bonarius » Tue Sep 17, 2019 12:03 pm
Same for me. There is an ~20% chance that the warming message shows up with the 25Ohm resistor.
Ali G
Astra Model: Opel Astra Enjoy 1.0 ST
Astra Colour: Coconut
Post by Ali G » Wed Sep 18, 2019 4:20 pm
Hi.
I ordered these indicator bulbs from Ebay. Installed them today on a Astra K Sports Tourer 2018. No warning in the dash. Thats nice...
https://www.ebay.co.uk/itm/2X-BAU15S-Amber-LED-Canbus-Error-Free-Turn-Signal-Indicator-Light-Bulbs-12V/113845265581?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Scotty_b
Astra Model: 1.4T 150 Sri
Astra Options: Flux Capacitor
Post by Scotty_b » Wed Sep 18, 2019 10:52 pm
They Ebay leds look ideal for us non electrical folk.
pav_blu
Astra Model: Astra K 1.4 XFT, 110 kW / 150 CP, 6-speed manual
Astra Colour: Black Meet Kettle
Contact:
Post by pav_blu » Wed Sep 25, 2019 9:25 am
Great guide, thanks for your time invested in making this.
