TPMS reoccurring fault 10 minutes after relearn
Steve3369
Post by Steve3369 » Mon Feb 11, 2019 12:37 pm
Hi all
Anyone shed some light on this please?
I had a TPMS fault showing on the dash with front left sensor not giving a reading. Got myself a relearn tool and went through the process as described and relearn was successful and all wheels showing a reading on the dash. All good initially with PSI changing as I put air in and as tyres warmed up however after 10 minutes on the move TPMS showing a fault with front left no reading again. Have repeated the process with the same result - every time after 10 minutes on the move fault shows. 10 minutes static (engine on and off) no fault. Tried disconnecting battery (system reset) no different. Tried taking tyre of and checked the fit of the sensor. No problem there.
Seems strange the sensor works fine after relearn but just for 10 minutes. Could it be a battery low in the sensor?
Next thing is to try a new sensor however before I do was wondering if there is something else I could try?
Thanks in anticipation.
Steve
Return to “How To”
