Removing the instrument bezel
Crunchynut
Post by Crunchynut » Wed Jan 17, 2018 7:26 pm
Hi,
I've got a lot of rattles from the bezel that surrounds the instruments (driver display, spedo and rev counter, fuel and temp).
How is it removed so I can silence them?
Elite 1.6 CDTi 136ps Hatch
Scotty_b
Astra Model: 1.4T 150 Sri
Astra Options: Flux Capacitor
Re: Removing the instrument bezel
Post by Scotty_b » Thu Jan 18, 2018 10:40 am
Very Simple.
1. Remove the plastic trim either side (usually piano black), they are just clipped in.
2. Remove the top part of the steering cowling, again just clipped in.
3. This will expose 2x 7mm bolts.
4. Pull and the clips will release from the top.
trembel
Astra Model: ST Innovation
Astra Colour: White
Post by trembel » Thu Jan 18, 2018 10:18 pm
I've got the same issue. I've used self adhesive Tesa foam to isolate instrument panel from surrounding plastics, but it didn't heal all of the noises. I've found out some noise is coming from inside of the instruments. Tried to separate plastic back cover from circuit board and frame, but it's still not OK.
Astra K ST, 1.4 92kW, Innovation
Zafira B, 1.7cdti 92kW, Enjoy+, Astra H Caravan, 1.7cdti 74kW, Enjoy
2x Astra G Caravan, 1.4 16v 66kW, 2x Astra F 1.4 16v 66kW/1.6i 55kW
Crunchynut
Post by Crunchynut » Thu Jan 18, 2018 10:40 pm
Very Simple.
Thanks. I'll give it a try.
Return to “How To”
