Dashcam installation with pics of placement
Supermann25
Astra Model: MK7 Astra K Tech LIne 1.6 CDTI
Astra Options: Android Auto & Apple Carplay
Contact:
Re: Dashcam installation with pics of placement
Post by Supermann25 » Thu Dec 07, 2017 6:31 pm
Thanks for the reply mate. I am going to attach a photo of the fuse that came with the dashcam and my question is can this one fuse let the rear wipers and dash cam work at the same time ?
Sent from my SM-G950F using Tapatalk
danh23
Astra Model: Sri cdti
Post by danh23 » Thu Dec 07, 2017 6:33 pm
I would swap that for a nextbase hardwire kit that has the piggyback connector on
Supermann25
Contact:
Post by Supermann25 » Sat Dec 09, 2017 12:58 pm
Thank you for the advice mate. The nextbase wiring kit worked great. All fitted and working fine now. I had to use the 4th bottom from left fuse as shown in image below so it works with the ignition on and off. I have attached images showing where i wired the cable through on the centre console as I couldn't find this anywhere ImageImageImage
danh23
Post by danh23 » Sat Dec 09, 2017 1:04 pm
Thank you for the advice mate. The nextbase wiring kit worked great. All fitted and working fine now. I had to use the 4th bottom from left fuse as shown in image below so it works with the ignition on and off. I have attached images showing where i wired the cable through on the centre console as I couldn't find this anywhere ImageImage[IMG]//uploads.tapatalk-cdn.com/201712 ... 9e56f3.jpg[/IMG" rel="nofollow"><span>https</span><span>://</span><span>uploads</span><span>.</span><span>tapatalk</span><span>-</span><span>cdn</span><span>.</span><span>com</span><span>/</span><span>20171209</span><span>/</span><span>a7fc422cdcf6ee6a7bc36ba64ea35b28</span><span>.</span><span>jpg</span><span>[/</span><span>IMG</span><span>][</span><span>IMG</span><span>]</span><span>https</span><span>://</span><span>uploads</span><span>.</span><span>tapatalk</span><span>-</span><span>cdn</span><span>.</span><span>com</span><span>/</span><span>20171209</span><span>/</span><span>7d16b84437417c7a0bbac5da68e21dd3</span><span>.</span><span>jpg</span><span>[/</span><span>IMG</span><span>][</span><span>IMG</span><span>]</span><span>https</span><span>://</span><span>uploads</span><span>.</span><span>tapatalk</span><span>-</span><span>cdn</span><span>.</span><span>com</span><span>/</span><span>20171209</span><span>/</span><span>c54c92b7d977b71cfa27ce72769e56f3</span><span>.</span><span>jpg</span><span>[/</span><span>IMG</span></a>]
Your welcome where your cable is coming out that's where mine is did you have any trouble with your A pillar
Supermann25
Contact:
Post by Supermann25 » Sat Dec 09, 2017 2:16 pm
that was actually the easiest part ! :lol:
I had trouble with grounding as didn't have the tools so borrowed from local MOT garage up the road.
also i dropped the fuse in the car lucky i had more in the house :lol: :D
other than that all was fine. Cheers again
Wellman
Astra Model: 1.6 CDTI SRI 136bhp
Astra Options: 18" bi colour alloys
Astra Colour: Granite Grey
Post by Wellman » Thu Mar 01, 2018 8:18 pm
Excellent how to mate, fitted mine today. £12 for the kit off e bay and £1.50 for a trim remover kit. Really easy to fit. Just one question, did you file off some paint to get a good earth connection of just connect it behind the washer? I didn't fully remove the washer and just slotted in the connection earth behind the washer . I hope it's a good earth.
danh23
Post by danh23 » Thu Mar 01, 2018 8:20 pm
My earth is behind the panel in the passenger footwell loosened the nut abit to slip the earth on and has worked for the 6 months I had the car
Wellman
Post by Wellman » Thu Mar 01, 2018 8:38 pm
Excellent, that's where I fitted it, behind the washer as it was more slotted in. When I first fitted it I done it behind the bolt and on top of the washer but because the fork did not fit over the bolt put it behind the washer. I didn't rub any paint off to get a good earth but if you have had it fitted that way for so long without any problems it should be ok, cheers
lucifer
Astra Model: K
Astra Colour: Royal Blue
Post by lucifer » Tue Jun 12, 2018 7:15 pm
I have A118c and hardwire kit with piggy-fuse. I want to use rear wiper fuse (found that some of you are using that fuse too), but I have no idea how many amp fuse should I use. Anyone could help please? Thanks.
Astra K 1.4 101PS Royal Blue
danh23
Post by danh23 » Tue Jun 12, 2018 7:48 pm
I'll take a look tomorrow for you and let you know
Return to “How To”
