Powerflex bar
connor.b1
Powerflex bar
Post by connor.b1 » Wed Sep 27, 2017 5:58 pm
Hi guys. In my Sri nav it does not have the power flex bar,it only has the indent to hold your phone but I would like to fix the powerflex in its place. This is the one I'm looking at
https://m.ebay.co.uk/itm/GENUINE-VAUXHA ... Ciid%253A1
Now I've had a look behind mine and it's just a fuse box so if any one has done this change or know how to that would be great.
I'll upload pictures of what I've got and what's behind it. Thanks
Sent from my MotoG3 using Tapatalk
Corbil
Astra Model: 1.6 Cdti Innovation 136bhp
Re: Powerflex bar
Post by Corbil » Wed Sep 27, 2017 8:45 pm
It would be useful someone to make a know how about this installation.
For sure you have to remove also the side trims of the console and the gear box trim as I have seen in the installation guidance of this item.
connor.b1
Re: Powerflex bar
Post by connor.b1 » Wed Sep 27, 2017 10:46 pm
Do you think it would be easy to do as I really don't won't to pay £70 for the part and then not be able to fit it
Corbil
Re: Powerflex bar
Post by Corbil » Thu Sep 28, 2017 6:43 am
It depends by your experience and how you can handle the tools.
Its not easy to dismantle the whole gear console if you don't have a specified step by step sketch. You might break something without the sketch.
Thats why Iam asking, if somebody install it already and has pictures of the dismantling, it would be nice to have it here as a guidance.
If not the only way to do it is to visit your experienced garage.
connor.b1
Re: Powerflex bar
Post by connor.b1 » Thu Sep 28, 2017 6:56 am
If I can dismantle the centre console then where does the connector go
Corbil
Re: Powerflex bar
Post by Corbil » Thu Sep 28, 2017 9:23 am
The only stuff that I can find on the net is this in the picture below.
I don't know how to use the link http://www.ifz-berlin.de in order to find the correct brochure for this installation.
Hilly
Re: Powerflex bar
Post by Hilly » Thu Sep 28, 2017 11:44 am
I fitted one lst weekend.... very easy to do... i would get one from a dealer or get it yourself.... you get the loom with the kit and i bet ebay will just send the bar and not the loom... i got mine for 65 haggle with the dealer...
To install remove the old fuse cover, pull out the gear gatter. Remove 2x hex screws undeneath. Pull firmly on the ac control unit from behind. Unplug the unit. Remove the 2 side covers in the footwells they just pull off. Remove the 2x 8mm bolts from footwells... move both seats forward.. remove 2x 8mm bolts on rear. Slide the centre console back Becareful of the wiring. You dont need to fully remove it... yiu can get to the 12v socket loom via the gear stick hole
Astra K SRI Navi 1.6 CDTi (110ps)
Previous cars
Nissan qashqai tekna 1.6 dci
Nissan qashqai tenka 1.5 dci
Nissan juke nismo 1.6 2wd
Nissan qashqai 360 1.5 dci
Nissan qashqai n tec +2 1.5dci
smart barabus roadster
Ford focus st3
Renault Megane rs
Corbil
Re: Powerflex bar
Post by Corbil » Sat Sep 30, 2017 10:48 am
Connor if you try it make a nice DIY with pics for the rest of us
Corbil
Re: Powerflex bar
Post by Corbil » Mon Oct 23, 2017 2:13 pm
Any news about the installation of your new gadget?
Did you install it already ?
Corbil
Re: Powerflex bar
Post by Corbil » Fri Nov 03, 2017 6:07 am
Ok just received my flexbar today.
The steps for the installation are shown in the following pictures
Return to “How To”
