Sport Button Astra Elite
mattonecz
Astra Model: Enjoy 1.4T 125
Astra Options: front and rear park. sensors, dual clima
Astra Colour: white
Re: Sport Button Astra Elite
Post by mattonecz » Sat Sep 16, 2017 7:53 am
The car still has same power, the button doesnt change it. So full throttle is the same.
2016 1.4T 92kW, Enjoy - Dual AC, front and rear park sensors, 17"
EDS Phase 1 180PS/290NM
2018 Honda PCX 125
Ty5500
Post by Ty5500 » Mon Oct 16, 2017 4:04 pm
I have the sport button on my 1.4 turbo 150 hp. Wouldnt do it again, dont like it at all and almost never use it. The engine becomes super nervous and as explained it is just the same as using more force on the accelerator. Result is that the engine feels more powerfull when barely touching the accelerator but the accelerating when flooring it is totally disappointing. And rev matching or similar is impossible because the revs will skyrocket when pressing the accelerator in neutral.
JJ-Yorks
Astra Model: 5-door SRi 1.0Turbo
Post by JJ-Yorks » Thu Oct 19, 2017 12:14 pm
Best feature on the car is the Sport switch....wouldn't be without it....might not make the car faster but it drives a hell of a lot better with it on..doesn't cause the car to rocket forward unless you want it to...all I can say is if you cant control the throttle you shouldn't even be on the road
1.0Turbo Power Red (130PS/225Nm Torque :D )
AdieMcc
Astra Model: Astra K 1.4T 150
Post by AdieMcc » Thu Oct 19, 2017 5:13 pm
I always drive with it on.
NIGHTCD
Post by NIGHTCD » Thu Oct 19, 2017 5:37 pm
Have successfully programmed the orther bits that was missing
Display - have activated the Sport Mode (displays sportmode on/off)
Steering - activated Sportmode
Throtle - not a thing to change
Auto gearbox - nothing to change
It seems like there is a little more responsive steering, but van not feel anything when engaging
It seems like the Throttle response may be there, but it is not so mouch notisable
Auto gearbox - holds on the gear on a lower gear.
So i do not know it it is like this it should be or not.
If there is anyone who have this by factory that can confirm if this behavor is as expected i’ll be happy
ROBINHOOD
Astra Model: 1.6 CDTI SPORTS TOURER EXCELLENCE
Astra Options: AGR + SUNROOF + 18'' STEEL RIM + NAVIGATION + F1
Astra Colour: WHITE
Post by ROBINHOOD » Fri Oct 27, 2017 1:00 am
Hi guys,
I want to do it as soon as possible
:roll: :roll: :roll:
6 full button part number: 39028756
its frame ( piano black ) part number : 13448083
ASTRA K SPORTS TOURER 1.6 CDTI 136HK AT EXCELLENCE + NAVI900 + AGR + 18" BICOLOR RIM + SUNROOF + SPORT FUNCTION + AIRWILNESS + INTELLILUX LED MATRIX HEADLAMP + F1 STEERINGWHEEL + GHOST SPEEDOMETER
NIGHTCD
Post by NIGHTCD » Fri Oct 27, 2017 4:40 am
Hi guys,
Hello,
Nice to hear 😁
You have to change the buttons and frame as pointed, then you’ll have to get tour dealer to request an VCI code for you, and the dealer have to program the VCI code and the orther bits (stated in my previos post)
ROBINHOOD
Astra Colour: WHITE
Post by ROBINHOOD » Fri Oct 27, 2017 7:57 am
Thanks for your suggestion.
ROBINHOOD
Astra Colour: WHITE
Post by ROBINHOOD » Fri Oct 27, 2017 8:03 am
Hello,
Nice to hear 😁
Does the sport button you retrofit work well ?
ROBINHOOD
Astra Colour: WHITE
Post by ROBINHOOD » Fri Oct 27, 2017 10:59 pm
NIGHTCD, Do you have button socket information available ?
Which cables are the cabling of the sports key?
Return to “How To”
