Sport Button Astra Elite
Daviasht
Astra Model: Elite Nav 1.4 T 150PS
Post by Daviasht » Mon Jun 05, 2017 7:50 am
Hi,
Can the sport button be retrofitted into the Astra Elite.
Summit White 1.4T 150 Elite Nav | Delivered 14/12/2016 | MY16.5 | Tinted Rear Windows | Under Boot Storage Kit | Front & Rear Mud Flaps | Interior LED's | Sunglasses Holder | Extra Boot Light | Sports Seats (AGR - Approved) :D
NIGHTCD
Re: Sport Button Astra Elite
Post by NIGHTCD » Mon Jun 05, 2017 8:20 am
Have not successfully managed to do this,, the Opel Tech will not provide my an VCI code to program it yet..
is still in search to find an Opel dealer that would provide med the VCI code (and program it into the car for me)
karlos
Astra Model: 1.4T Elite
Post by karlos » Mon Jun 05, 2017 8:25 am
I would like to know this too. I would bet that there's no special parts required other than the button, it's just a question of whether there's some kind of lockout coded into the ECU that prevents it from being retrofitted.
NIGHTCD
Post by NIGHTCD » Fri Jun 30, 2017 5:37 am
Have then managed to get the VCI code programmed into the car by an Opel dealer her in Norway.
Have also fitted a brand New sport button (Complete unit behind the gir shifter), but the sport button does not lights up and there is no response to the car..
Is there anyone With the sport button fitted that can respond to some of my questions?
- is there any Sport settings under the settings menu ?
- is there anyone that can provide a Picture of all the fusebox in the car (under bonnet, inside the car and in the boot)?
- is there any sport settings in the instrument clusters menu?
regards
jt123
Post by jt123 » Fri Jun 30, 2017 8:14 am
regards
I can help with these two
No
No , it just pops up on the Screen with "Sport Mode on" or "Sport Mode off" when you press the button.
NIGHTCD
Post by NIGHTCD » Fri Jun 30, 2017 10:36 am
thanks for the reply..
maybe there is an unit on the cars with sport button or maybe there is an update missing.
would be nice with some pictures of some fusebox'es
cornishtaz
Post by cornishtaz » Fri Jun 30, 2017 12:59 pm
Do you know which ECUs were programmed? I'd have thought as a minimum the BCM, engine ECU and IPC need programming.
cornishtaz
Post by cornishtaz » Fri Jun 30, 2017 7:17 pm
Do you have all the wiring to the BCM?
NIGHTCD
Post by NIGHTCD » Fri Jun 30, 2017 8:43 pm
I do not know 100% but i know the BCM is programmed.
NIGHTCD
Post by NIGHTCD » Fri Jun 30, 2017 8:44 pm
There was another thread at the forum with pictures to the Sport Button and my car has the same wiring..
Return to “How To”
