Yes, the passanger side one is just clipped on, there's screw at the back on the driver's side panel.
Subwoofer and Amplifier install
Re: Subwoofer and Amplifier install
Has anyone managed to find a 12v remote turn on wire in the rear or easier to obtain? Cheers
Would there be anyone willing to install an set of front speakers/amp/sub for me in my 66plate 1.6cdti elite?
for a few greenbacks plenty of tea and a few beers if your local:)
Im based in Bucks
cheers
Im based in Bucks
cheers
Anyone know how to replace those, it's only 4 sets of speakerwires, shouldn't it be some sort of crossover installed? Or is it some sort of dsp in stereo, but regardless it's only 4 sets of speaker wires, anyone that have changed speakers and can tell how they did with the crossover that comes with the aftermarket speaker+tweeter sets.
- Astra Model: '16 Holden Astra BK
- Astra Colour: Cosmic Grey
Exactly what I've wanted to do to mine.. Thanks for the how-to!
I've been planning to (but haven't had the time) replace the factory speakers with something more punchy. I can't even get the volume up 3/4 without the speakers either cracking or becoming muffled/no punch. Have you upgraded your speakers too?
- Astra Model: Astra K SRI VX-Line
- Astra Colour: Blue
I’m also wanting to know about the tweeters/mids in the dash, I haven’t taken anything out yet So can’t see how I would run a set of components with a decent cross over, unless a new wire can be run to the tweetes then the cross over can be tucked away under the dash.
Another issue would be the actual mounting of the tweeter, I pulled the grill off today to have a look and take pictures. Does anyone make adaptor rings for these or is it going to be a DIY?
- Astra Model: Elite Nav 1.4T 150
- Astra Colour: Carbon Flash
If I am just installing a KSC-SW11 Kenwood will a simple fuse tap/piggy back work ok for power and would I still need a remote wire power on wire if connected to an ignition switched fuse?
Does anyone know what gauge these wires are, and do scotch lock/t-connectors work ok?
I cant see how I would connect into the plug as per the 1st post, what was crimped onto the end of the wires connecting in?
WOW!
Where is the fuse for the cigarette lighter/ 12v socket?
