Repeat fault
scocart
Re: Repeat fault
Post by scocart » Thu Mar 26, 2020 3:51 pm
Awesome. Many thanks. I’ve just got it back after the latest “fix” so will see how it goes. I won’t bet my house on it lasting long!!
Crosseyxpower
Astra Model: Sri nav
Re: Repeat fault
Post by Crosseyxpower » Thu Mar 26, 2020 5:39 pm
What was the "latest fix"?
scocart
Re: Repeat fault
Post by scocart » Thu Mar 26, 2020 5:45 pm
They have changed a sensor. This is the third sensor so I’m not holding out hope
Re: Repeat fault
Post by Redman » Thu Mar 26, 2020 9:00 pm
You quote a sensor! Have they actually replaced the same o2 sensor again or a different sensor?
The evap valve being faulty sounds very plausible to me as Mullybully has suggested. This has been mentioned on the cruze forum also. I didn't suggest it because the posts had more than the P015B code coming up.
If I were you and the latest sensor replacement doesn't solve it, I would insist they replace the evap valve and show them Mullybully's post. The evap valve is fixed under the inlet manifold and is a bit tricky to get to. Good luck.
Crosseyxpower
Re: Repeat fault
Post by Crosseyxpower » Thu Mar 26, 2020 9:21 pm
B10 xft
Circled is the part mentioned above.
scocart
Re: Repeat fault
Post by scocart » Thu Mar 26, 2020 10:00 pm
Blimey, thanks folks. I’ll definitely go with that info next time. I’m a bit daft when it comes to mechanics so appreciate any suggestions
scocart
Re: Repeat fault
Sorry I didn’t answer your question, it is the same sensor
Re: Repeat fault
Post by Redman » Fri Mar 27, 2020 6:49 am
Looking at that picture the evap valve is a lot more accessible than on the 1.4T. Looks an easy task on the 1L T to replace.
Crosseyxpower
Re: Repeat fault
Post by Crosseyxpower » Fri Mar 27, 2020 9:23 am
Second that, will be near the bulk head but shouldn't be too much of a issue.
Crosseyxpower
Re: Repeat fault
Post by Crosseyxpower » Fri Mar 27, 2020 10:19 pm
