Astra - smoke from engine bay
rmiddletonj
Post by rmiddletonj » Sun Feb 09, 2020 1:41 am
Can anybody help please? I have had smoke coming from the engine bay for some time. When stationary and the cooling/heating (air con) is on, the smoke seems to also come inside the car.
I have had part of the exhaust replaced and also had an oil change as I thought it could be an oil leak and oil was burning.
I have uploaded a video via YouTube if anybody would mind reviewing? Hoping someone can help as unsure what this but don’t want a big bill for a garage to fix it!
AdieMcc
Astra Model: Astra K 1.4T 150
Re: Astra - smoke from engine bay
Post by AdieMcc » Sun Feb 09, 2020 6:06 am
Oil leaking on the bottom of the cat. You sure your oil filter is tight enough?
rmiddletonj
Post by rmiddletonj » Mon Feb 10, 2020 12:27 am
I would hope as I’ve just had an oil filter change, will check it out, thanks!
FilipSvozil
Post by FilipSvozil » Sat Oct 17, 2020 9:33 am
Hello,
Just wanted to check, did you by any chance found out what the issue was? I had a full service and it started smoking in exactly the same way as yours.
