Rear Light Cluster
WhelanUK
Astra Model: SRI
Rear Light Cluster
Post by WhelanUK » Sat Dec 29, 2018 7:03 pm
Strange issue, was driving home indicated right and a whole host of errors popped up on my dash about my rear lights.
Got home an looked, turns out all the light in my rear drivers side cluster are not working. Tail light, indicator and brake. Seems strange that all the bulbs would go at once. Too dark to look now but has anyone had a similar issue?
Re: Rear Light Cluster
Post by astraowner » Sat Dec 29, 2018 7:19 pm
Well if all lamps are not working, the best action would be to look for something they have in common.
GND/Chassis/negative connection would be my first guess.
WhelanUK
Astra Model: SRI
Post by WhelanUK » Sat Dec 29, 2018 7:59 pm
That was my thinking. Will take the cluster out tomorrow, just thought it was strange for everything to blow at once.
NeoVo
Astra Model: 1.6T SRi Nav (200)
Astra Options: Intellilux, Advanced Park, Winter Pack.
Post by NeoVo » Sun Dec 30, 2018 12:58 am
Maybe a bad fuse / loose connection?
Post by astraowner » Sun Dec 30, 2018 1:01 pm
For that to happen, there would have to be some sort of over-voltage situation, that would affect all bulbs, all bulbs would have to be lit at the time AND it would have to be contained to only that side, or else other bulbs would blow aswell.
Or all bulbs should blow at the same time.
IF this was the case, i would certainly buy a lottery ticket, because both scenarios would be incredibly unlikely to the point that winning the jackpot in the lottery would be much more likely to happen. :lol:
My money is on the GND gone missing :)
Post by astraowner » Sat Jan 12, 2019 4:30 pm
So did you solve it, and what was wrong.
Maybe usefull for futire reference
Rob14
Astra Model: SRI, 1.6 CDTI (136), 2016 plate
Astra Colour: Grey
Post by Rob14 » Sat Jun 15, 2019 3:36 pm
I've just had this issue on my passenger rear light cluster. Does anyone know what it would be?
I'm thinking the fuse. Where is the fuse for the light cluster?
SRI, 1.6CDTI, 136bhp, 2016 plate, Manual, Grey,
Rob14
Astra Colour: Grey
Post by Rob14 » Sun Jun 16, 2019 12:17 am
Update. I gave the plug a push and the cluster is working again. I think there may be a loose connection with the plug. I'll keep an eye out if it does it again.
eusty
Astra Model: 1.6 SRI Nav CDTI
Astra Options: Front parking sensors
Post by eusty » Sat Oct 12, 2019 9:52 am
Had the same issue with the same model/MY.
Same solution, must be some corrosion/tarnishing on earth connection of the plug?
Rob14
Astra Colour: Grey
Post by Rob14 » Sat Oct 12, 2019 1:06 pm
Mine has started doing in again intermittently. I was turning a corner yesterday and it flashed up the indicator had gone but mid corner it went back to normal. Same with Brake lights.
