New coil springs but now sitting low at front
Johnny00
Post by Johnny00 » Fri Nov 16, 2018 9:54 am
My Daughter has had new coil springs fitted to her 58 Astra 1.7 cdti eco estate by her local diy mechanic. The car now sits quite low at the front, it looks a bit too close to the tyres for comfort.
The mechanic insists that he has fitted the correct springs recommended by his supplier. Any thoughts?
Re: New coil springs but now sitting low at front
Post by Scotty_b » Fri Nov 16, 2018 11:35 pm
Definitely sounds like the wrong spring load.
NIGHTCD
Astra Model: Astra K Premium
Astra Options: all except sunroof
Post by NIGHTCD » Sat Nov 17, 2018 2:48 pm
Maybe it is the sport springs that is fitted
Sent from my iPhone using Tapatalk
2016 Astra Premium Nav - 1.4 turbo 150HK - Carbon Flash - Automatic
Post by Scotty_b » Sat Nov 17, 2018 4:50 pm
Could be as the sri was 15mm lower on the H, that coupled with the estate being heavier could cause it.
Johnny00
Post by Johnny00 » Mon Nov 19, 2018 1:49 pm
Thanks to all for your replies.
It would seem obvious that they are the wrong springs but the "mechanic" insists that they are the ones that the suppliers says are correct. Perhaps I need to talk to the supplier.
Thanks again
astraalecs
Post by astraalecs » Tue Nov 20, 2018 7:56 am
Could be that they bought springs for petrol rather than diesel car which usually has a heavier motor.
