Key gets stuck in ignition
M1chaelR
Astra Model: SRi 1.4 Turbo Auto
Astra Options: Winter pack, Front and rear parking sensors
Post by M1chaelR » Fri Jul 20, 2018 8:05 pm
My other half has said the key has started to get stuck in the ignition over the past few days when trying to take the key out and it's happened to me now as well. After some fiddling with starting the engine again and putting the car into gear and then park again then it will release. I'll get it booked into the dealer but does anyone know what it could be?
Thanks,
Mike.
iavorid
Astra Model: MY2018 1.4T 150 AT6 ST Innovation
Astra Options: Navi 900, WP1, Rear cam, Versitility pack, keyless
Astra Colour: Cosmic Grey
Re: Key gets stuck in ignition
Post by iavorid » Sat Jul 21, 2018 5:14 am
It may need some lubrication only. It's not necessarily broken or anything.
1.4T 150 AT6 ST Innovation in Cosmic Grey
M1chaelR
Post by M1chaelR » Sat Jul 21, 2018 12:21 pm
Thanks. The dealer has tried that this morning so fingers crossed that'll sort it :)
J155
Astra Model: 2017 1.4 turbo elite nav.
Post by J155 » Sun Aug 19, 2018 10:57 pm
Hello,
I am also experiencing this problem. Can you tell me if the issue was rectified by lubrication please. Is this something that is covered by Vauxhall under warranty?
M1chaelR
Post by M1chaelR » Mon Aug 20, 2018 7:31 am
Hello,
They first tried a little lubrication into the key barrel without removing it to see if it would sort it, as they couldn't fit us in straight away for a full diagnostic. It worked for a couple of weeks but it started jamming again. I booked a proper appointment then and they removed the key barrel to lubricate it all properly a week ago so fingers crossed that has sorted it. I'll update in another few weeks and let you know. I would have thought a replacement would be covered by warranty.
M1chaelR
Post by M1chaelR » Wed Aug 22, 2018 4:39 pm
Unfortunately it got stuck again today so I'll be taking it in next week for a proper diagnostic.
M1chaelR
Post by M1chaelR » Mon Nov 19, 2018 10:04 pm
Just to update on this one - Vauxhall technical came back to say that the gear lever (mine is an auto) needed replacing as the switch inside it wasn't working correctly to release the key from the barrel. It's been perfect since *touch wood*!
