USB Port not working
markfirman
Post by markfirman » Tue Feb 13, 2018 9:49 am
Hi all, first time poster here!
I upgraded to a 2016 Astra K, from an Astra J - really nice car! But I am having issues with the USB port and subsequent connection to Intellilink. When I first purchased the car, the USB port worked fine. It would charge the phone and I could use Apple carplay no problem. However, now it wont do ANYTHING! It wont charge, it wont work with Apple CarPlay or Android Auto.
I've tried about 20 different cables (some genuine) and about 5 different mobile devices, to no avail! So my question is, before I take the car back to the garage, is it possible that there is a fuse that has blown, that could be causing this issue?
Whats weird is that it worked and then suddenly stopped for no reason - I'm quite technical, and can see no damage to the port itself. Please help me, I am going crazy! Anyone else been in this situation - how did you resolve it?
Thanks!
moleyjoel
Astra Model: Elite Nav 1.6t (200) MY17.5
Astra Options: Intellilux, 18” Bi-Colour, Parking Pack, AGR Seats
Astra Colour: Mineral Black
Re: USB Port not working
Post by moleyjoel » Tue Feb 13, 2018 12:51 pm
You could try checking the fuse, according to the manual it’s number 28 in the instrument panel fusebox.
If the fuse is intact I would take it back straight away, it will be covered under warranty.
Hope this helps!
Elite Nav 1.6t (200) Mineral Black MY17.5
Intellilux LED, 18” Bi-Colour Alloys, Advanced Parking Pack, AGR Sport Seats
markfirman
Post by markfirman » Tue Feb 13, 2018 3:07 pm
Thanks for the reply!
Following your advice I got hold of the manual that shows where fuses are located and what each one is used for. According to the manual fuse 28 is for the USB socket. Upon removing the facia, it would appear I do not have any fuse in this position - which is odd considering the USB did work when I first brought it. This leads me to believe that fuse 28 controls the rear USB ports (not the one in the arm rest used for connecting to the Intellilink - I could be wrong though)
The only other fuse port it could be (in my opinion) is fuse 19 (my car has this one) and it is labelled as Data link connector - could this be the one? It has a 7.5 Fuse - although replacing it didn't fix my issue either. (or perhaps fuse number 34?)
I'm going to try removing the battery for 20 minutes to see if a hard reset will fix this annoyance.
moleyjoel
Post by moleyjoel » Tue Feb 13, 2018 5:51 pm
Ah my bad, you’re probably right, the one I suggested most likely is the rear ones then. :lol:
Hard to tell with some of the terminology they use in the manual, could be one of a few, so just check all possible fuses.
Has the hard reset fixed it? If not then take it in, as it’s most likely a loose connector, especially if it was working before.
ZA_hman
Astra Model: Astra K 1.0 Enjoy
Astra Options: Driver Assistance Pack 1
Astra Colour: Magnetic Silver/ Flip Chip Silver
Post by ZA_hman » Tue Feb 20, 2018 6:34 am
I had the same issue (I have a 2016MY as well) - and the USB just stopped working on day.
The dealer had trouble finding the fault as well - their feedback was that the port was getting power but "just not reading"
They eventually replaced the radio unit under warranty - and they reported the issue was common.
loonybin
Astra Model: sri 1.6 cdti
Astra Options: intellilux headlights & parking pack
Astra Colour: flip chip silver
Post by loonybin » Wed Feb 21, 2018 8:47 pm
my usb point has played up since new, only play music via memory stick with it, been in local dealer 6 times in total 4 x 1 day , 1 x 2 days and just got it back on monday ,in dealers since previous tuesday , various software updates as directed by vauxhall and changed the usb unit, fingers crossed ok uptil now.
tom1
Post by tom1 » Mon Mar 19, 2018 12:56 pm
Mine has a similar problem, was working fine but now won't recognise mine or wife's iPhones but think it recognises my old android, thought it might be a software update on the iPhone that did it but not so sure, maybe head unit not recognising iphone?
markfirman
Post by markfirman » Thu Mar 29, 2018 11:06 am
Just thought I'd give everyone a status update - as the issue is still persistant.
Took my Astra to the dealer for diagnostics around 12 days ago - they had the car all day and confirmed that the USB was not working. Today my car is back in the garage to have the new USB port fitted.
Hopefully this fixes the issue and I'll finally be able to use Apple CarPlay - though I've heard stories of other users having to replace the whole infotainment system. Will update here when I pick up the car later today :!:
moleyjoel
Post by moleyjoel » Thu Mar 29, 2018 2:34 pm
Glad they’ve *hopefully* sorted it for you, let us know the outcome later on!
markfirman
Post by markfirman » Thu Mar 29, 2018 3:48 pm
Just picked up my Astra - low and behold, the USB port is working again and it only took them a few hours :D
