Replacement Rear Wiper Blade
drm345
Astra Model: SRI NAV 1.4T Auto
Astra Colour: Asteroid grey
Re: Replacement Rear Wiper Blade
Post by drm345 » Wed Jan 03, 2018 2:47 pm
How does the blade detach? I assume the cover over the pivot hinges up to reveal a nut. I have tried, but I'm afraid of breaking something
NeoVo
Astra Model: 1.6T SRi Nav (200)
Astra Options: Intellilux, Advanced Park, Winter Pack, 18" Bi
Post by NeoVo » Wed Jan 03, 2018 8:40 pm
Fitted mine this afternoon. Although fitment on the underside of the wiper arm is different, it felt secure enough using the existing 13mm bolt.
Although I've not covered a huge distance yet, the extra visibility will be helpful.
Bought this from ebay: https://www.ebay.co.uk/itm/Rear-Wiper-A ... 2070466078
NeoVo
Post by NeoVo » Wed Jan 03, 2018 8:46 pm
On either side of the cover (protecting the nut), you have to gently pull the flexible bits (nearer the glass) outwards.
There was also a couple of nodules on the underside, so it's best to push it gently down towards the glass then in then opposite the length of the wiper blade.
Hardest bit was actually getting the existing blade off, it has like a bevelled ridge which keeps it securely in place once tightened; a slightly more aggressive wiggle in both directions free'd it
BRUCE225
Astra Model: ASTRA SRI VX-LINE NAV
Astra Colour: DEEP SKY BLUE
Post by BRUCE225 » Thu Jan 04, 2018 12:58 pm
Got them in work now so can confirm Bosch H253 looks correct.
oastra
Post by oastra » Thu Jan 04, 2018 3:57 pm
Do you fit them ? Or you just think that will fit ?
OastrA
BRUCE225
Post by BRUCE225 » Thu Jan 04, 2018 4:15 pm
No not fitted my cars only a month old so no need to change, and know if I try I will break something just for the sake of an experiment :D
But they are the ones listed and held up against wiper arm everything looks ok..
oastra
Post by oastra » Thu Jan 04, 2018 6:57 pm
Thank's for your sharing
OastrA
drm345
Post by drm345 » Fri Jan 05, 2018 6:00 pm
Thanks for the info, NeoVo
Crimson
Astra Model: Astra K 1.6 Turbo 200ps
Astra Options: Intellilux, drive assist, park assist, nav, + more
Post by Crimson » Tue Jan 09, 2018 8:48 am
Anupanu wrote:
Mon Dec 18, 2017 9:15 am
Hi Discorus, and welcome
I can't help you with the Bosch code for the Astra blade, but I replaced arm and blade with the Insignia Sport Tourer model, it is longer and gives a far larger sweep area.
In my opinion the OEM looks too small on the rear screen of Astra and this change fits perfectly (Hatch only) can't comment on ST
Once you change to the Insignia arm, you can find a Bosch blade.
Is the replacement blade you have used from the current or the previous Insignia model?
Summit White Astra 1,6 200 ps with Intellilux, Navi 900 Intellilink, advanced parking assistance, detachable tow bar, Open&Start key-less entry, tinted rear windows, AGR driver's seat, 40-20-40 rear seats, 2 extra USB for charging.
Anupanu
Astra Model: Elite 1.6CDTi 110
Astra Options: Intellilux, Driver & Parking Pack, AGR Power Seats
Astra Colour: Emerald Green
Post by Anupanu » Tue Jan 09, 2018 5:18 pm
Good point, when I originally did this there was only one Insignia model so, Insignia A
Had
5 Nova/Corsa
4 Astra, including current Elite in Emerald Green 1.6CDTi 110
4 Cavalier/Vectra/Insignia ST
Scotia Grey Discovery Sport HSE Lux
