£20 a wheel does not sound bad.rang Halfords Auto, and National, they all said because it needs programming they want £100 to do it.
finally got in touch with ATS - £20!
Good point, especially if your car was 5 years plus old, you needed 4 tyres. I'd then supply the tyre fitter with 4 sensors to fit whilst they're fitting the tyres. Easier that changing them later.Rule of thumb would be "If rubber needs replacing and the TPMS sensors are 4+ years", get them changed at the same time as they change the rubber, as it will cost almost nothing in labor for them to change the sensors if they have the rubber off of the rim anyway to replace it.
Well worth your time and effort of ringing around and doing a bit of researchsounds a hell of a lot better than the other big companies.
MOT and service time in July, that came round quick. I suppose at least this year it hasn’t happened a week before like the insignia used to do.
Beats going to the dealersATS would of saved me a lot of ringing around if they’d answered the phone 1st thing this morning haha, cos that is who I tried 1st.
Yes they are cheaper in comparison to main dealer, and probably the parts used by the main high street Garages. So yes I suppose there’s an element of risk. The reviews to the particular link above are positive, and 140 sold. So that’s reassuring they are the correct TPMS for the job.Make sure those sensors come programmed with an ID number. That price is quite cheap and I suspect they will be blank, not sure.
No doubt, it is an oem sensor and good at that, there shouldn't be any element of risk as it is a good make. If it comes with no programmed ID it will cost you to get it done.Yes they are cheaper in comparison to main dealer, and probably the parts used by the main high street Garages. So yes I suppose there’s an element of risk. The reviews to the particular link above are positive, and 140 sold. So that’s reassuring they are the correct TPMS for the job.
Exactly my thinking Valer. My 1600 is coming up to 6 years old in September and I'm guessing that the tpms sensors battery's will be getting near the end of their life so I'm watching this thread with interest.I think they should be ok Redman,
the pic shows the sensor with it's I.D. on the case and the reviews say no problems with learning.
i shall be keeping an eye on them for myself and maybe buy a set as spares.
Hopefully you contacted either the 1st or 2nd reviewer as the others are to do with a different e bay sellerI have also messaged one of those who left positive feedback, who has responded with a positive review, adding they have done approx 4000miles since it was fitted with no issues.
As you know Shaky,mine is a couple of years younger and i don't want the batteries to go flat before i have the need to fit them,oh decisions,decisionsExactly my thinking Valer. My 1600 is coming up to 6 years old in September and I'm guessing that the tpms sensors battery's will be getting near the end of their life so I'm watching this thread with interest.![]()
You are more than likely to be right Valer, just thought I would mention about checking it out for being supplied with ID.I think they should be ok Redman,
Good point, however I believe they are plugged into some sort of machine or checked to be functioning before they are fitted to the wheel, so the likelihood of knowing if they work or not will be known before the tyre is put back on the rim.Is it possible to connect these to your tpms without fitting them, to see if they work? What I mean is, presumably if you just sit the new sensor on the wheel it will be in range of the receiver, so you can set it up in advance of taking the tyre off. That would save paying a fitter to do that only to find they don’t work.
