This a detailed tutorial to retrofit antithief alarm system to astra k
i use used part from astra k 1.4t to astra k 1.6.cdti.all vauxhall astra k part are suitable for opel astra k.
part needed :interior light 13437064
it's preferred to bought this part with its wire loom like picture :
we need also siren part, preferably with loom wire:
the alarm sensor have 5 wire:
1 black, 1 red/yellow, 1 green/brown, 1 yellow / blue, 1 violet /gray
picture :
the siren have 3 wires:
black, red/yellow, green/blue
picture :
the switch have 4 wires:
black, violet/gray, yellow, yellow /bleu
picture:
now i will explain where every wire goes to:
(black switch to black sensor) goes to black of front doom light
yellow of switch goes to yellow of front doom light
yellow bleu of switch goes to yellow /bleu of sensor
violet /gray of switch goes to violent /gray of sensor
(red/yellow sensor wire goes to red/yellow of siren) goes to fuse 10A any empty one
green/brown of sensor goes to bcm (pink X6 color pin 16)
green /bleu of siren goes to bcm(pink X6 pin 9)
shematic :
the lastest step is to add a wire from sunlaod sensor to BCM x1 white color pin 21.
to get this work you need a Vci code.
for any questions contact via pm
picture :
picture :
picture:
shematic :
